2 weeks ago there is some leakage in washing mashine then it satars to show error 15.leakage and error have not show on 40 degree program but when i increase the water degree they are start.
SOURCE: error message "test"
yhe washing machine has been put into test mode to get out of this mode you must press and hold down the On/Off and Start/Cancel buttons until "d off" is displayed that will get you out of the test mode
SOURCE: Zanussi Aquacycle 1200
Pump jammed or filter blocked, check filter if not blocked remove pump and replace if faulty. Regards Advisor
SOURCE: I have an 03 error displayed on a Bosch WFK 2801
03 error code is the drain. Disconnect the drain hoses and check for blockages. If no blockage "time" the drain interval. If it's more than 6 minutes it's the pump. Also make sure you're using the correct type of soap so the ball check valve on the bottom of the outer drum isn't getting fouled with excessive suds. Also disconnect the drain hose from your house plumbing and let it free flow on it's own. This will tell you if the blockage is in your plumbing and not in the machine.
SOURCE: sud message Bosch washing machine
ur using too much soap rinse and spin and use less soapwhen u wash
Testimonial: "thanks-- how do you know how much soap is enough?"
SOURCE: Hi, How Can I Reset error in my wash machine Bosch
Error code reset on Classixx 6 1200 Express
The post above is correct, just missing one detail, see below;
You can reset the error code by the follow steps.
Turn the knob to the off or reset position, 12 o'clock.
Turn the knob to the 6 o'clock position. Wait for Error code to flash
Press and hold the spin button and while holding the spin button turn the knob to the 7 o'clock position (Drain position)
Continue holding the spin button for about 5 seconds then release the spin button and now turn the knob to off. Wait 5 seconds
When you turn it back on it should have cleared the error code.
Thanks Dan what shoud i do now?HOw can i solve this problem?
The most common reason for this is because food debris has clogged up the drainage system.
1. remove the standing water
2. remove the bottom sprayer arm and clean it out
3. remove the screen and clean it out
4. check the drainage area, dislodge any other clogs
5. put the dishwasher back together in reverse steps
Thanks very much for your help.I did 4 items but i don not underestand"put the dishwasher back toghether in revers step".please tell me what shoud i do?
Please reverse the steps that you followed to assemble the dishwasher.
