Question about KLH Audio Players & Recorders
How to connect my klh psw8-100 sub to my stereo and tv
On my klh subwoofer the high speaker output stop working the sub works just fine but when I hook up the other speakers to it they don't play at all. I know if I go and buy a receiver I can bypass it.
The speakers connections have to come from an amplifier with sound coming from it in the first place. Once connected to the unit the bass signal is then extracted from the signal and the rest of the signal sent to the main speakers. The KLH will not power the main speakers on it's own. The unit will only take the two main stereo channels, from an amplifier, the left and right then go to one set of inputs and they then come out of the other two outputs.
Dec 27, 2016 | KLH Audio Players & Recorders
Trying to hook up a KLH sub woofer, S100ETH, PSW8-100 to a VCR reciever. Reciever has sub woofer connection but does not works on the KLH sub woofer. What is the problem ?
I suggest you go over your receiver set-up instructions. See if you need to set the receiver to acknolwedge the addition of the subwoofer. It should be in your receiver set-up steps. Just as a check, hook up one of your other speakers to the subwoofer lead to see if gets audio signal. I'm guessing the issue is your receiver settings.
Jan 06, 2015 | KLH Audio Players & Recorders
How to connect to TV
Find the "Sub Out" connector on your TV. Likely an RCA jack. Run a cable from the TV to the Sub's Input and you're done. If your TV doesn't have a Sub Out then you might be out of luck.
Jun 21, 2014 | KLH ASW12-120 Subwoofer
How to connect a subwoofer to a klh 5100
this unit has a sub output on the back to connect to a powered sub, or an amp/reciever and passive sub
Mar 09, 2013 | KLH R5100 Receiver
I have a KLH SW-90 amp. When I plug in the RCA plugs I don't get any sound to the Satelight speakers. Is this a sub amp? Do I need to hook up the high input wires to make the satelight speakers work?
I have the same amp. there a two ways to use it: The phono plug inputs are low level, are for use as an amplifier only, and their only output is the subwoofer output. In this case, any stereo satellite speakers would be driven directly from your stereo amp.
The high level inputs are meant to be driven as the same as speakers from your stereo amp. A circuit inside samples the bass and directs it to the sub amp and output. this same circut passes unamplified outputs to the satellite outputs. PM me at moestevens@cox.net if you need further info.
Oct 24, 2010 | KLH Audio Players & Recorders
How do I connect this subwoofer to my reciever
The simplest way is to insert the sub into the speaker wire run -- connect your receiver's speaker output to the sub input, then the sub output to the speakers.
These are the "High Level" connectors on the left side of your sub.
If your receiver has a subwoofer out (either one or a stereo pair) then you'll get better quality sound by connecting that output to the "Low Level" connector or connectors on the right. If you have stereo, then use both connectors. If your receiver only has one subwoofer output, then connect it to the left (may or may not me marked as "mono" depending on the age of your sub)
Hopefully that helps. If it's confusing, post back questions or post the details (brand and model) for your receiver.
If it's helpful, please hit the Thumbs-Up for me!
Oct 16, 2009 | KLH ASW10-120 Subwoofer
Add su bwoofer to KLH 200
the subwoofer i have, a polk, connects directly to the right and left speaker lines of the klh2400.
i then connect my stereo left and stereo right speakers to the subwoofer.
essentially, the subwoofer becomes a middle station between my speakers.
make sense?
Jun 06, 2009 | KLH KL2400 Tuner
Loud humming buzzing sound coming from subwoofer
make sure you have the speaker connection right if you do then it is a ground problem try plugging it in a different outlet
Dec 16, 2008 | KLH HTA-4906 System
Installation Help
This means that you have purchased a three piece home theatre system. Two tweeters and a sub-woofer. Assuming you are using a Stereo player (Tape/CD/DVC)you have to connect the Left Output of the Stereo placer to the Left Input at the back of the Sub-Woofer and the Right output to the Right input of the subwoofer by cables. Then take tweeters and connect them to Right speaker and Left speaker output at the back of the sub-woofer ( note if the speakers are marked L/R, then connect them to the subwoofer output accordingly. In case you are using a 5.1 player, then only connect the front right and front left to the Right and Left input at the back of the subwoofer. You are and you can now start playing your music or movies and and you will get theatre quality sound.
Aug 22, 2007 | KLH (AT2100) System
138 people viewed this question
Top KLH Audio Players & Recorders Experts
 Grubhead
Grubhead
Daniel Dollive
Daniel Dollive
Are you a KLH Audio Player and Recorder Expert? Answer questions, earn points and help others
