SOURCE: how do you hook up to charge a jazzy 600
your charger plug fits under the controller joy stick. It has 3 coverd prongs [email protected]
SOURCE: I'm trying to remove the wheelchair seat from the
hi
I hope this helps
http://www.pridemobility.co.uk/docs/UK_Jazzy_1103_om.pdf
Regards
GeWiz.
SOURCE: Somehow I have locked my Jazzy 6 Select Electric
Try This:
To unlock the power chair.
1. Use the on / off button to switch the control system on. The maximum speed / profile indicator will be rippling up and down.
2. Deflect the joystick forward until the control system beeps.
3. Deflect the joystick in reverse until the control system beeps.
4. Release the joystick, there will be a long beep.
5. The power chair should now be unlocked.
Hope it works.
SOURCE: replaced battery in jazzy 600
Make sure that your drive wheels are engaged and the power chair is not in the freehweel position (so it can be pushed).
SOURCE: Hi I purchased a used jazzy 1103 for my father and
the seat post is probably rusted in the post. Try lifting the handle and twisting the seat and pulling up at the same time it can really be very hard but keep trying and maybe get some help to lift as it is being turned. I've had to use a hoist to lift it off the floor and twist the seat until it comes out. Hope this helps
