Try here;
https://manuall.co.uk/alba-lcd19880hdf-lcd-television/
Page 19 is the stuff you'll need.
You will need an aerial plugged into the TV to receive the DTV signal in the first place.
Best of look.
SOURCE: my alba lcd32880hdf turns on
Sound and screen have different power circuits and protection fuses. If you are competent to can take the thing apart, if not get a technition to check it out. NO way do you have any electrical supply connected when you take things apart or even do not attempt to plug it in while the electrics are exposed. YOU COULD KILL YOURSELF AND OTHERS STANDING NEARBY
SOURCE: alba lcd32880hdf tv
Ive got a albe Lcd32880HDF And the picture goes off 14 months old sound only?
SOURCE: 32" ALBA 15 MONTHS OLD.
I am afraid it sounds as though either your backlight or power inverter has gone faulty, may be worth contacting alba to see if they will honour the warrenty (unlikely but worth a go) otherwise maybe try your home insurance to see if its covered, failing either of these options, if you feel confident doing so, disassemble the tv and look for any signs of visible damage (capacitors leaking or any components looking burned or scorche, and replace. Try looking for any panel markings which will allow you to search for a price to replace the whole unit.
Unfortunately I cant give you and hard and fast cure, and it is very difficult to tell whether it is the inverter or the backlight has gone (having said that, if you are getting picture at the very beginning, it may suggest that the inverter is getting the power to the backlight ok, which may suggest its the backlight at fault.)
Hope this helps.
