SOURCE: Nikon CoolPix Flash Problem
This happened to me too!
Turn the dial to setup, push the menu button & select reset all. This will restore the defaults & let you use the flash again.
SOURCE: Flash not working
I figured out how to fix the flash... but not the clicking sound in the lens. To fix it... click the mode button, then go to the settings icon
(the arrow pointing at the wrench), then keep going down to the reset all part. and click okay while your on it. Your flash should work after that!
SOURCE: Horizontal lines on image
This is not a solution , but only a work around. If you do at least 1/3 zoom on your lens before clicking a photo, these lines will not appear. But this not not a convenient way I agree.
Also this surely means that the CCD is not the problem otherwise it would have never worked ( electronic parts cant simply dont start to work when you zoom ringht ? ). Surely Nikon is fixing the issue, but cheating the customers by charging for a part is not defective in the first place
SOURCE: my nikon coolpix l110 does not fire its flash even
Hi, your Coolpix have the xenon tube exausthed if ready led light but dont fire. Best regards
SOURCE: can't access the flash menu on the Coolpix L5.
Carol, did you ever figure this out? I can't access the flash menu either. Email me if you have a solution - [email protected]
