SOURCE: compaq presario v5000
Depending on your Bios Version I think later then V44 fixed a bug that would cause your computer no to start if the battery was dead with the V5000. Remove the battery and try booting from just AC power.
I have also had the same issue when my bios battery is loose or dead. The battery can be accessed from the memory area. Once you open it on the left should be memory and on the right will be the wifi card. You don't need to unplug the cables just remove the wifi card and examine the battery. The battery is held by a very very flimsy piece of platic and really easy to break. The best thing I have found is using a little piece of cardboard from a box or something and using it to keep the battery tight, just dont go shaking the laptop alot and it will hold it. It might also be possible your bios battery is dead.
From what I say I would hit power it would power for about 3 seconds the power light would flash then turn off.
SOURCE: Toshiba Satellite M100 Laptop fails to boot
trying holding the F8 key and they may give you a recovery option which could be the only way you can get your system up and running
SOURCE: Computer won't boot Windows Vista. Screen goes black with cursor arrow.
In this case you have to do the PC restore . you can do that in dell machines by shutting down the machine and when it is coming back on just HOLD DOWN THE CTRL ket and the START HITTING f11 key in this case you will lose the data which you have the on the c drive but this issue will get resolved .
Else you can try to restart in the safe mode with networking and then go to the system restore and then select the bold dates in which you have idea you system was working fine . selct the date and then do the system restore . In this case you will not lose the data but you will lose the updates which you have done after that date .
in both the cases system will work .
SOURCE: medion akoya will power on but not boot windows
I am an Medion specialist. These computer suffer with problem motherboards which often cause random restarts and shutdowns. The same applies to all Advent and Emachine computers sold via the high street stores. Need help to repair, email me me at [email protected] or ring me on 07926-106150
Click the "Start" button.
Type "System Configuration" (without quotes) in the search box and select "System Configuration" from the search results.
This will open Microsoft's System Configuration utility.
Click the "Boot" tab.
Clear the "Safe Boot" check box under "Boot Options."
Using the Windows Boot Menu
Turn on your computer.
Press the "F8" key repeatedly immediately after the BIOS screen appears.
The BIOS screen typically displays the logo of the computer manufacturer.
Select "Start Windows Normally" from the boot menu and press "Enter" to proceed.
or
Restart your computer
during the boot process you will see on the screen a certain key to press usually the Delete or F2 to enter setup
Press and hold that key during the boot up process to enter BIOS using the arrow keys you can load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
hope it helps
Hello, here are the steps to resetting your computer.
Reinstall Windows from a Disk
1 Turn on your Toshiba Satellite. Insert your
recovery disk or the original Windows operating system DVD
into the Satellite's
CD/DVD drive. Turn off the computer.
2 Turn on the Toshiba Satellite. In the first
few seconds while it is starting up, press and hold the F12 key on your
keyboard to access the Boot Menu. (Note: Some Toshiba models may tell you to
press "C" to boot
from the CD-ROM). The screen will display boot for
this boot up session only.
3 Use the arrow keys to navigate. Select the
CD-ROM/DVD drive to highlight it. Press "Enter." Be aware that this
setting is for this session only; it is not a permanent change.
4 Allow the computer to start up. Follow the onscreen
instructions for reinstalling the operating system from the disk.
Reinstall from a Recovery Partition
1 Boot up the Toshiba Satellite. In the first
few seconds while it is starting up, press and hold the F8 key. This will begin
the "Advanced Boot Options" menu.
2 Use the arrow keys on your keyboard to navigate
the menu. Move the keys to select "Repair Your Computer." Press
"Enter."
3 Select your language and keyboard; click
"Next."
4 Select your Windows user name from the
drop-down menu. Enter your password if required. Click "OK." This
will begin the "System Recovery Options" menu.
5 Select the Toshiba Recovery Wizard and follow
the onscreen instructions. The Toshiba Recovery Wizard will delete all existing
data on the hard drive and reinstall Windows.
Hope this helps!
