SOURCE: What is the code for a Sanyo DP26640 26" LCD TV
Hello 1. Turn on a device (e.g., VCR or DVD Player) and, if applicable, insert media, (e.g., video cassette or disc). NOTE: Please read steps 2 to 6 completely before proceeding. Highlight or write down the codes and device you wish to program before moving on to step 2. 2. On the remote control, press a device key once (i.e., AUX or TV). NOTE: Use the AUX key to program control of an Audio Amplifier or Receiver, a DVD Player, a Home- Theater-In-A-Box Device, a PVR (or DVR), or a VCR. 3. Press and hold Setup until the selected mode key blinks twice, then release Setup. 4. Locate the code for your device in Manufacturer's Codes on the back of this user guide. Brands are listed in alphabetical order with the most popular codes listed first. 5. Enter the first four-digit code for your device. If you perform this procedure correctly, the selected mode key will blink twice. NOTE: If you enter an invalid code, the selected mode key will display one long blink and exit the programming mode. Repeat steps 2 to 5 with a valid code. 6. Aim the remote control at your device and press Power once. The device should turn off. If it does not respond, repeat steps 2 to 6, trying each code listed for your works. If it still does not work, try Searching For Your Code. NOTE: If the device does not have a
Remote code for Sanyo TV with Comcast Custom DVR-3 device universal remote control is
0154
brand until you find one that
Power key, press the (Play) key
SOURCE: whee is the analog audio output for sanyo dp26640
After reviewing the manual ( http://www.manualslib.com/manual/306783/Sanyo-Dp26640.html#manual - page 6), it does not appear that this television has an analog output. A fix to this problem would be to purchase a digital to analog audio converter (just Google this) and some inexpensive solutions are available.
Good luck,
SOURCE: how do I program my Magnavox remote for a DP100MW8BA to a sanyo tv DP26640
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the relative post easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
Search the site by type in the brand name of your device, in the "Search box at the top right of the Home page display" to see the set-up codes to your device, with different brand remote controls.
Check and replace the main system control memory IC. Before doing anything; just try a hard reset first. If it do not help you, do the replacement said above. There are two types of reset to TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
