SOURCE: Brown spots coming from steam iron
you can mix 50% water with 50% vinager let it set in the iron overnight then turn it on and let the steam run out.What happens is the inside of the iron where the water is had corroded or rusted or has lime deposits.the vinager will break this loose overnight.also after you let the iron steam out all the mixture,flush the iron 4 to 5 times and start using fresh water from a store bought gallon.your tap water is probably full of iron.
SOURCE: Rowenta steam pressor about 5 yrs. old
Push the small brown/grey button just below the pump button, then pull the handle down to disconnect it. The top of the handle inside, has a cap you can peel off, and add water there.
Fill with 50/50 water vinegar solution. Get it good and hot and let it sit for two hours. Rinse and repeat if necessary. Buy a gallon of water from the market and use that from now on. This will fix your problem. The Iron is concentrating the iron in you water and this is what is causing the brown spots. Hope you find this helpful. If you do please take the time to rate it fixya and maybe I will keep helping people for free.
George
SOURCE: My Rowenta Garment Steamer will not steam up.
Ok. This thing is caused by scaling. If the steam generator runs out of water the sensor thinks the tank is empty and causes the machine to go to standby (basically switch off -- orange light comes on). The solution: Open the machine and clean it.
MAKE SURE THE POWER CABLE IS UNPLUGGED BEFORE ATTEMPTING TO DO THE FOLLOWING:
1. There are six screws ( phillips - you will need a long screwdriver). Two of them are hidden under the wheels (just pop off the rollers and you will see the screws)
2. Open the steam generator (there are four screws) and be very careful with the 'O' ring -- you damage it and you can say good bye to the machine. Clean it if you see scaling. The amount of scaling present would indicate how hard your water was. This itself may not be cause of the problem but now that you openend the machine, you might as well as clean it for better efficiency.
3. Disconnect the hose to the steam generator (it has two circlips) and clean it. Mine had hard deposit of scales preventing the water reaching the steam generator.
Re assemble it.
Good Luck
Alex0714
SOURCE: my new laurastar steamer is not producing steam at
plse call customer service on 1800 999 910
If the iron heats but steams improperly, inspect the soleplate and clean the vents (see below) and flush sediment out of the steam chamber .
If the iron produces too much or too little heat, test the electrical cord . Also test and, if needed, adjust calibration of the thermostat .
If the iron does not spray properly, inspect and clean the nozzle.
If the iron leaks or spits, clean the steam vents, nozzle, and tank.
If the iron sticks to fabric, clean or repair the soleplate. If the iron stains fabric, clean the soleplate, clean the tank with a commercial cleaner, and use distilled or filtered water.
