Hardware & Accessories Logo
J
Jorge Echevarria Posted on Mar 07, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Replace entire keypad on the paragon 7700 wall safe
john h
Level 3:
Top Expert:
  • Master 29,494 Answers
  • Posted on Nov 03, 2021
john h
Master
Level 3:
Top Expert:
Answers
29494
Questions
0
Helped
7559296
Points
193449
Notify a lock smith
How do I get replace keys. Original ones lost. Model 83-DT5915
You posted to the category 'Cars and Trucks'? This appears it may be a wall safe. All question need 'make model (what it is)', first 3 words please.
An advert states
The safe also includes two manual override keys, so you never have to worry about being locked out. :>)
It appears to be made by Paragon.
https://images-na.ssl-images-amazon.com/images/I/B1qBk7-jM1S.pdf
And that leads me here
Key Replacement
Team Customer Service https://teamcustomerservice.com > key
Key Replacement For Paragon Lock & Safe and Stalwart. Verification of ... Replacement Keys are $35. This includes the key and all shipping and handling costs ...
We have a Paragon model 83-DT 5912 wall safe. We know the code.
We don't do iChat, everything is done here.
I don't really see a question in your post, but here is a Paragon wall safe manual although different models.
https://images-na.ssl-images-amazon.com/images/I/B1w7iNzNmLS.pdf
More here and more manuals
https://www.google.com/search?q=Paragon+83-DT+5912+wall+safe+manual
How to reset Paragon Lock & Safe model 7803 without code or keys please?
question edited for clarity and removal of text message abbreviations :>)
So the girlfriend got inside first and took all the good stuff and left the door open with the locking bolts out and deployed? :>(
Page 3 of the manual. You press the red reset button and change the pass code to a new one. Change the batteries as well at the same time. This is the better manual. Other left below
https://docplayer.net/40344439-7803-paraguard-deluxe-electronic-digital-safe.html
INSTALLING BATTERIES
Open the battery compartment cover located on the inside cover of the door. Install the batteries as shown on diagram (4 AA
batteries). Close the battery compartment cover.
SETTING AND CHANGING PERSONAL CODE
1. Open the door and press the red button at the rear of the door. The yellow light will flash.
2. Set a personal code, input a 3-6 digit set of numbers.
3. Press "
" or "
" to confirm.
The yellow light will turn off, indicating the code was entered successfully.
Use the same procedure to change the code.
4. Test your code before closing the door.
USING YOUR PERSONAL CODE TO OPEN THE SAFE
Input your 3-6 digit personal code then press "
" or "
" to confirm. When the green light flashes, turn the handle clockwise to
open the safe.
OPERATING MANUALS
https://images-na.ssl-images-amazon.com > images
PDF
Thank you for choosing a Paragon Lock and Safe product. Paragon Lock and Safe (PL&S) warrants the ... www.paragonlockandsafe.com for return instructions.
I have a paragon 7700 it is stuck closed.
If the key is not working, then unfortunately you will need to call a locksmith to open the safe. There is no other way to open the safe without the key.
How do i set code for paragon safe
INITIAL BATTERY INSTALLATION
1. Remove the key plate cover, insert the key into the keypad and open the door.
2. Remove the battery cover plate located on the inside of the door.
3. Install 4 AA batteries provided and replace the battery cover.
NOTE
: If both the red and green lights are on while the safe is open, this indicates that the batteries are low and need
to be changed.
TO SET UP OR CHANGE A USER CODE
1. With the door open, locate the red button on the back of the door near the hinge.
2. Press the red button and listen for the beep.
3. Immediately enter your new passcode (3-6 digits long)
4. Immediately after entering your new passcode, press the "A" or "B" button on the keypad. Your new user passcode is now stored.
NOTE:
This safe stores up to 2 passcodes (a user code and a manager code). Entering a third code will erase the
first passcode entered.
SETTING UP OR CHANGING A MANAGER PASSCODE
1. Open your safe with the passcode you wish to change and leave the door ajar.
2. Press the "0" button on the keypad twice. Press the red button, listen for a beep and then enter your new user passcode.
New user passcodes may be 3-6 digits long.
3. Immediately after entering your new code, press the "A" or "B" button on the keypad. Your user code is now changed.
OPENING THE SAFE
1. Input your code and then press the "B" button, the green light will turn on.
2. Turn the knob clockwise within 5 seconds to open the door.
3. Each key pressed will be accompanied by a buzzer and a yellow flashing light. If the entered code is invalid the yellow light will
flash and the buzzer will quickly sound, this indicates the code needs to be re-entered.
CAUTION
: Entering the incorrect passcode 3 times will lock the system for 20 seconds.
More information can be found in the attached document web page.
http://www.paragonlockandsafe.com/manuals/mastermanual.pdf
Resetting combination on Paragon 7875 Depository Safe?
To reset the combination on the Paragon 7875 Digital Keypad Depository Safe, you will need to locate the reset button on the back of the safe. Once you have located the reset button, press and hold it for 3 seconds. This will reset the combination to the factory default of 0000. You can then enter a new combination of your choice.
Top Paragon Hardware & Accessories Experts
john h
Are you a Paragon Hardware and Accessory Expert? Answer questions, earn points and help others
