SOURCE: I found this serial number tag on my harley
The second part of the number past the "vin:" is probably the VIN of your bike, maybe not but it looks like a VIN number. Your VIN should be stamped into the neck of the frame. What the first number is, I have no idea.
SOURCE: i really need a wirring
If you'l Google 'H-D golf carts", you'll get lots dealers that sell the manuals and the schematics are in those. The manuals aren't that expensive and contain all the info you need to fix anything that goes wrong with your cart. Believe me when I tell you that the manual will pay for itself. The reason I say this is because there is NOT ONE THAT WILL WORK ON ONE OF THESE CARTS as far as I know of. The H-D dealers won't even look at one. Since parts are sometimes hard to get, the other cart dealers won't mess with them either. So, you're relegated to doing you own work. You need the manual.
Good luck
Steve
SOURCE: i have a golf cart
http://i130.photobucket.com/albums/p271/bernsidecycles/shovel/install_hi4_new.jpg
Simple standard ignition switch diagram for Harley-Davidson Motorcycles, hope this helps!
SOURCE: have 4 wires (red, green,
may i recomend to replace the switch rather than install a toggle. you have the wires exposed and maybe the switch out. it will be clean and preform better. Fran [mechanic]
SOURCE: need a manual for my
You can download and print the instruction manual for Yamaha G16A golf cart in PDF format by clicking this link.
Adobe PDF Reader is required to view this manual. Download Adobe Reader
Hope this helps. Kindly let me know if you have any difficulty in downloading the manual.
Thanks for using FixYa.
Your feedback is important to us!
Kindly rate and accept the solution if it helps you.
I found the manual for you're here in PDF format
http://www.buggiesgonewild.com/gas-harley-davidson/41795-free-harley-golf-cart-manual.html
