IN PRESSURE COOKER MODE THE FLOATING VALVE DOES NOT GO UP TO SEAL THE UNIT.
SOURCE: Steam coming out of floating valve on handle.
No. if the steam is coming out, the vent valve is not seated on the vent and pressure won't build up. Either remove the plastic cover from the vent valve or slide it up enough so that the valve seals on the vent. If you remove the plastic cap, you will need to manually tilt the valve to "quick-vent" the cooker. Watch out for steam burns! Should work fine after that. You need to unplug the cooker and re-plug it to reset the "E4" error message.
SOURCE: Looking for place to order replacement Seal Ring
Replacement parts for the Wolfgang Puck pressure cookers are available here:
http://www.wpcookware.com/categories.asp?cat=29
If you do not see the part you require or are unsure about the model number; suggest you contact their Customer Service at 1-800-275-8273 or via their webform at:
http://www.wpcookware.com/contact.asp
Sorry someone has not responded sonner.
SOURCE: Looking for a replacement part
Hi, take a look on amazon, click here
Holiday cooking made easy No plugs No fuss and chose which one fits. I hope this was helpful. Cheers
