SOURCE: sounds like a loose belt.
Most surpentine belts have an atomatic tensoner. I have had 2 fail on different cars and it is a simple fix, both of them required removal of one bolt.
SOURCE: Kicker CVR making strange noise
I purchased this kicker saturday. Monday mine made the same weird noise. wednesday i had time to take it back where i got it and they replaced it but as soon as i did it made the same noise. they gave me another one and said if i have problems with it they will replace it. i have a feeling this one will do the same thing. They told me it is a problem with the speaker so maybe try taking it back and telling them what happened and getting a new brand
SOURCE: where to tighten belt on reebok280 treadmill?
there should be 2 end roller caps, one on the left and one on the right. in these caps there will be an allen key bolt, turn each one a full turn to tighten the belt. continue to turn these bolts until you are happy with the belt tension.
SOURCE: The treadmill belt is making a noise and feel like
If it has a low pitch growling when you start unit then the running belt is too tight and the adjusting bolts need to be backed until the growling noise is lessened or eliminate without the running belt slipping.
If it is the drive belt slipping, the adjustment bolt is underneath the frame so you will need to elevate the treadmill and adjust the bolt until slippage is eliminated without over tightening the drive belt.
SOURCE: the belt is loose on treadmill how do I tighten it
Is the belt drifting side to side? If so, adjust it with the Allen bolts on both sides of the base. If the belt is just slipping, has your treadmill had a lot of use? If so, you may need a new belt. You can order one at Treadmill Parts
