Music Logo
V
Vasya Angelov Posted on Mar 06, 2018
Im looking for all the Roland JV-90 plastic push butons.
Can anyone tell me how to adjust the pitch bend range on a Roland JV 2080?
Software, download the Owners Manual and get into it.
How to open a Roland RA-90 to replace battery
Get the manual from web site and it will tell you how to replace the battery.
My screen is out on my roland jv 80 keyboard
This problem will require servicing. The screen is bad, and has to be replaced.
Roland jv-90 button repair
I.m looking for all the ROLAND JV-90 plastic push buttons.
2answers
I have a Roland AC-90. During a gig last Sunday I had my Taylor acoustic guitar and a Shure mic cutting out. There would be a break in sound - both guitar and voice would go - and then it would all come...
I would expect there is bad soldering or a circuit board crack. Inspect the soldering aound the leads, especially pots and heavy components. Finding all the retaining screws can be frustrating. Expect the screws for the handle to also attach to the amp chasis. They are often hiodden under plastic caps.
F4 button pressed in
Most of the Roland buttons on this type equipment use a small switch that is actuated by a plastic button that is HINGED from a plastic panel behind the faceplate or a part of it. These plastic hinges get broken when too much force is applied to the button... it is USUALLY fatal and requires replacement of the whole button faceplate... and they are expensive... contact Roland parts to inquire.
1helpful
2answers
Key won't come back up on Roland digital piano
Roland FP is a nice keyboard but has a known problem on cracking key weights. There is a counter weight under each key to push the key upward. There are two sizes of weight beams, longer one for white keys and shorter one for black keys. Roland did not make the original weight beams strong enough to last. They will crack and eventually break. When it happens, the key will stay down. Fortunately, they can be easily replaced.
Roland FP-8 has 4 black screws at the bottom on each side end. Remove the screws, flip the ends up and expose the interior. Near the hinge of the problematic key, carefully ply open the hinge tabs and remove the key from the hinge. You will find a weight beam under the key. Remove and inspect the weight. There should be a metal wrapped in a plastic beam. If the metal part is missing, find the missing part and replace with a new beam. You can order weight beams from Roland. It costs about $10 each plus shipping. Put everything back in the reversed order.
Oct 01, 2009 • Music
Top Roland Music Experts
NOEL
NOEL
Are you a Roland Music Expert? Answer questions, earn points and help others
