My Lynx 24 outdoor refrigerator stopped running It is less than one year old. Any troubleshooting advice?
It had stooped once before but I reset the outlet and it was ok. The outlet circuit was broken after a brief power outage. This time I reset outlet and everything worked except fridge!
Due to being less than 1 year old , you need to call a Whirlpool factory authorized service center for repairs . This repair will need to be done under warranty . You could try unplugging for a few minutes and then plug back in to reset the electronics .
You said,
your fridge stop cooling including the freezer section, motor is running okay. This is a ice maker Frigidaire. Help , please.
What is the model number?
And how old is the fridge?
First try to unplug the fridge for 5 minutes and then turn it on again and see if we reset the system.
If not then you have a bad thermostat or leaking freon, and the pressure is too low to cool anything.
Or,if the compressor went then you may find this article I just read interesting!!!!!!
Repair or replace?
When to pull the plug on your old refrigerator
It nearly always makes sense to undertake simple do-it-yourself repairs,
such as replacing a gasket on a refrigerator or a freezer.
Typically, you'll also find a troubleshooting section for more-serious problems
in the owner's manual.
Should you pay for a repair or buy a new model?
The answer depends mostly on the age of your refrigerator,
how much you bought it for,and the cost of the repair.
Follow these guidelines:
When a repair makes sense.
If your refrigerator is under warranty or less than four years old (three years for top-freezers),
paying for a repair makes sense.
Note that refrigerators under warranty might require service from a factory-authorized technician;
readers have found them on a par with independent repairers.
When a repair might be a wise choice.
If your refrigerator is out of warranty and is four to seven years old,
it might make sense to pay for a repair. Customers generally pay $100 to $200 for a repair.
But you might want to buy a new model even at this stage,
given that today's models are quieter and have added features.
Higher energy efficiency is another plus: Energy Star-qualified models made after April 28, 2008,
are 43 percent more efficient than conventional models built before 2001 and 56 percent
more efficient than those built before 1993.
When it pays to replace.
The repair costs more than half the price of a comparable new refrigerator.
Data also shows that it doesn't pay to fix a less-expensive top-freezer refrigerator
six or more years old or a bottom-freezer or side-by-side eight or more years old.
Thanks to better recycling programs, less than 10 percent
of a refrigerator you replace is likely to end up in a landfill.
Please remember to enter a rating before you sign off!
Thank You, HUUUM
You said, your refrigerator isn't running - food getting warmer and the light is on inside
Need clarification
What is the model number and the year?????????????
Do you hear only silence
Check that there is still power in that outlet.
You can use a small lamp to test the outlet for power.
When you unplug the fridge to test the outlet, leave the fridge off for 5 minutes.
Then plug it back in and see if this reset the system.
You may have a freon leak and the compressor will not turn on.
If the fridge is old you may find this article I just read interesting.
Repair or replace?
Thank You, HUUUM
Hello okons , Welcome to fixya. I'm Huuum and happy to assist you,
You said, Your freezer will not stop running, it's very cold.
I see that you did off and on! Did you turn it off and then unplug it? Or if for some reason you can not reach the plug, turn the breaker off instead! Leave it off for at least 3 minutes to your watch! Then when you return power to the appliance and turn it on, it will reset itself and perhaps this will remedy the problem! If it does not remedy the problem I would say the thermostat is faulty. Let me know what happens! Bless You, Huum
How old is the freezer?
Here is an interesting report I just read!
Repair or replace?
It nearly always makes sense to undertake simple do-it-yourself repairs, such as replacing a gasket on a refrigerator or a freezer.
Typically, you'll also find a troubleshooting section for more-serious problems in the owner's manual.
Should you pay for a repair or buy a new model? The answer depends mostly on the age of your refrigerator, how much you bought it for,and the cost of the repair.
If your refrigerator is under warranty or less than four years old (three years for top-freezers), paying for a repair makes sense. Note that refrigerators under warranty might require service from a factory-authorized technician; readers have found them on a par with independent repairers.
If your refrigerator is out of warranty and is four to seven years old, it might make sense to pay for a repair. Customers generally pay $100 to $200 for a repair. But you might want to buy a new model even at this stage, given that today's models are quieter and have added features. Higher energy efficiency is another plus: Energy Star-qualified models made after April 28, 2008, are 43 percent more efficient than conventional models built before 2001 and 56 percent more efficient than those built before 1993.
The repair costs more than half the price of a comparable new refrigerator. Data also shows that it doesn't pay to fix a less-expensive top-freezer refrigerator six or more years old or a bottom-freezer or side-by-side eight or more years old.
Thanks to better recycling programs, less than 10 percent of a refrigerator you replace is likely to end up in a landfill.
Thanks for giving me the opportunity to help! Please do not for get to give a rating before you sign off!
Hello
Welcome to fixya.
I believe your problem is an old thermostat or compressor ! How old is it?
My advice is do not put good money into bad!
A new fridge will pay for itself in a few years by using a lot less electricity!
Repair or replace?
Please remember to leave me a rating before you sign off!
Thank You, HUUUM
Since the ice maker is erationally starting and stopping at it's own leisure.
1.We must first try to turn off the fridge.
2.unplug it or if you can not reach the plug you can turn off the breaker to the fridge also, for 5 minutes!
After this you restart the fridge and see if the system reset it self.
This is a common way to reset some units!
If nothing works then perhaps the ice maker needs to be replaced.
How old the fridge?
Let me know how it works and if you have any questions.
Please remember to give a rating before you finish..
bless you
Huuum.
Here is an interesting article I just read.
Repair or replace?
Sounds like your thermostat is malfunctioning. Do not let it keep going like this without service or it will burn out the compressor soon by running non stop.
How old is the fridge????
now that's expensive and not worth investing in if the fridge is 10 years old or more the new refrigerates use much less power and can change your electric bill for the better !
Below I referred you to a great service nation wide!
Here is a good company that's found nation wide. A&E Factory Service A&E has schedulers available to take appointments 24/7 And they do warranty work too, for most manufactures! 1(800) 905-9505
You will be fine Bless You ngafm1 PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OF
Hello Hamid,
The unit is designed to run the indoor fanmotors continuously when in cooling mode on both indoor units (evaporators). The reason is that this circulates the air and the temperature thermistor or sensor is able to sense return air temperature and in turn start or stop the outdoor unit and compressor as required according to the setpoint temperature. The reason for either unit not reaching setpoint temperature can be a couple of reasons. A) Incorrect design - the unit may be too small for the application. You can calculate this roughly at 650BTU per square meter of room in a relatively warm ambient climate. Or secondly B) The outdoor unit has leaked and is short of refrigerant. You can check this when the outdoor unit is running by feeling the thicker copper tube on the right hand side of the unit. This should be cool to cold. If no temperature difference is felt, it is short of refrigerant. Hope this helps you. Goodbye
