to change the brightness of your samsung galaxy tab, you need to open the shutter at by dragging your finger from the topmost where you will get the settings for brightness. You can also change the brightness in the settings menu. Thanks
You have a contact issue with your battery. ..even plugging it in you must have a good connection with the battery. I would try this take a piece of cardboard or paper and fold and wedge it in between the battery and the outer edge of the battery recess not where the gold colored terminals are located. Sometimes the battery don't make proper contact and this will ensure that it does. After doing this plug it in and let it charge for a while. When the icon for the charging battery gets to about the middle of the battery then hold down the on button until the icon disappears let go of the button and see if it works ok
Try this lol, This works with devices having physical home button:- 1. Press the power button and the home button together
for a while, long enough until the screen appears with Android bot and a
progress bar which shows that it's formatting the internal memory. With NO physical HOME button:- 2. In case your device does not have a physical home button, press the power button and both the volume keys together for few seconds. 3. Press gently the "reset pin-hole" present generally on a side of Tablet. Use a clip-pin or similarly fine thing to gently push inside to reset your device to factory settings. NOTE: You'll not only lose the apps on your internal memory and the data associated with it. All the device updates will also be lost and you'll have the version of Android your tablet came with.
