I Bought a Canon Legria FS306, whenever i put the adapter with the SD card inside the camera it always says that '' the card is set to prevent erasure '', i checked online and apparently i need to put the switch on the unlocked position, i did so but the message still shows up, the card doesnt show up on the configs menu thus i cant initialize it, please help, im using a 16gb sandisk ultra microsdhd 1 with a sandisk adapter
SOURCE: Question for SanDisk SD card
There is a small switch in the card that is currently in the locked position. you need to move it over to the other position to unlock it.
SOURCE: My Canon A460 Digital camera displays ''card locked''.
There is not many things that could cause this symptom. The card lock position mechanism is faulty and will require a replacement circuit board. Most likely about a 20-30 dollar part.
SOURCE: How to format an SD card on a Canon SD600 camera
Could be that you have the wrong memory card.
SD600 will only work with the old SD cards, but the SD780 will take the SDHC cards.
SDHC was intended to give 4gb or more of storage, while the old SD started as 16 mb. Different cameras have different limits, but it is always best to assume that the practical limit on an SD card is 2mb. Even if the SD780 will take the SDHC cards, it can be more practical to only carry 2GB SD cards and know that they will fit either camera
maybe the camera cant handle the amount of Gb the card has good luck!
