Unplugged fridge to clean under and now the display screen will not stay on. Lights up when buttons are held down but goes off soon as buttons are released. Nothing will run except lights on inside when doors are open
Tmaries0406:
Thank you for your review.
We would like to inquire further about your review with you. Please respond back to this email address, [email protected], with your name, phone number, street address, zip code, model & serial number, and date of purchase on the appliance.
We look forward to your reply.
Thank you,
Whirlpool® Social Media Relations
SOURCE: Cannot get car out of "Valet mode"
First start by looking inside the cars fuse box, there should be a fuse named "ROOM". Take it out and check if its still good. If not replace with the same amp fuse.
SOURCE: door chime and courtesy light (under side mirror)
You have broken wires in the flexable harness between the door and the body. Pull the rubber boot back to inspect.
SOURCE: Rear Door Handle Broken
I had the same problem, and here is the solution:
http://www.findonefindall.com/toyota-sienna/siennareardoor.htm
It includes step-by-step instructions and photos. I printed it and headed to the garage. I while later (hours actually) it was fixed. I did end up going to the hardware store and buying the EXACT size screw they recommend. I went with a screw rather than a nut and bolt. Worked fine.
SOURCE: 1993 Lincoln Town Car interior lights and chime won't go off
If key is on locks go down and pop up. If key is off, locks stay locked
SOURCE: '04 Nissan Altima can't be trained to open garage door.
Hello , you are probably not doing anything wrong. Some garage door openers will not accept some codes. My Toyota Tundra 2005 worked on my garage door , but my 2004 F250 would not. Quinn , Arizona
