My personal suggestion would be to go for these repair catalogs. I know this website reliable-store.com that i used to buy them from, and they have online it was very good
manual. Go ahead, I bet.
Do you have the owner's manual? This one shows how to install the bobbin in a top=loading machine:
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&ved=0ahUKEwiPgcHwn9bZAhVP-GMKHSZhBIkQFggrMAA&url=https%3A%2F%2Fwww.janome.com%2Fsiteassets%2Fsupport%2Fmanuals%2Fprofessional-series%2Finst-book-mc9400p.pdf&usg=AOvVaw3sYqlJaGbegtoLS8F6SxoP
Here's a video:
Janome 9700 Sewing Machine Review Part 1
SOURCE: bobbin thread getting jammed
kyoungblood4
Are you making sure that your pressure foot is up when you thread the upper thread? If it isn't then your thread is not seating correctly in the tension disks. It will then be loose and make a birds nest(mess) under what you are trying to sew. The other thing to check is which way you are putting the bobbin into the bobbin case, different machines do it different ways. Some want the thread to come out of the case in the same direction as the slot on the case and some want it to come off in the opposite direction.
Guest,
Probably when your son broke the needle he knocked it out of time. You will need to have a sewing machine technician to repair that.
Hope this has been helpful for you bothl Liz M
SOURCE: Janome 7021 needle is not catching thread from bobbin
did try joann fabric store or some other sewing store in the area
SOURCE: Bobbin holder problem. Needle hits bobbin holder
Is the needle all the way up in the holder? Have you checked the timing with the bobbin and the needle. Look in your manual for needle timing
SOURCE: Needle hits the bobbin holder and doesn't grab the bobbin thread
Also note that using a red band Singer needle will cause this exact symptom. The Singer needle is about 1.5 mm too long for use in any other machine. Ensure that you're using a standard needle. (Schmetz and Klasse are good examples.)
Your machine may also be out of time, which would require professional repair.
-R
SOURCE: will not pick up bobbin thread
Unusual for this machine. Check to be sure the needle is inserted with the flat side to the back of the machine. If it is, remove the needle plate, bobbin and bobbin case. Turn the hand wheel slowly toward you and see if the point of the hook is above or below the eye of the needle when the hook point is aligned behind the needle. If the eye is above the point of the hook the machine is out of time and best taken to qualified technician.
