What OS?
what disk?
no raid card stated, no array stated, no type of array stated.
One can put 100s of RAID cards in this server.
both raid cards or HBA cards,(forJBOD)
i can fix any server, but first need to know what is in the box first
you meant the boot disk has errors, right,? boot.
that would tell me the disk IS BAD.
but if and ARRAY , that means you must run SMART tests
on the disks, 1 by 1 to find the bad disk.
if smart shows its bad, or weak its for sure BAD.
on real servers. the server sends you email, (set up right)
telling you disk 3 in a RAID 6 is bad, replace it now.
are you running hardware or software raid, or HBA or
fake raid cards, (4 classes there.!)
the base system new has.
4 port SAS 5/i integrated SAS controller (no RAID_
and optional, from DELL , news.
Optional PERC 5/i integrated SAS/SATA daughtercard controller with 256MB cache,
PERC 4e/DC, PERC 5/e adapter
or any of 1000s of other aftermarket cards there.
I run LSI 9361s (with MSM appl loaded)
this card will tell you what disk failed every time no kidding.
so will the PERCs setup correctly
the PERCs and my LSI and my HP raids
all have installed monitors for the RAID ,a program that runs full time all the time, and reports errors , many ways,
did you load that first and use it? seems not.
as no mention of SMART at all.
good luck.
Im not sure the names on DELL , MSM like software.
ah its OSA
never run a PERC lacking this APP. or you can not keep the server on line,.
http://www.dell.com/support/search/us/en/04#q=Dell%20OpenManage%20Server%20Administrator&sort=relevancy&f:langFacet=[en]
SOURCE: boot problem
The BIOS is detecting the cdrom but it is not detecting the Bootable cd I have in the CDROM
SOURCE: Biostar P4M800-M7A Motherboard SATA RaiD Mirror Array As C boot Disk
hi, you need not have to upgrade the BIOS,, set the SATA HD on the IDE channel in the BIOS, or what options r avilable for SATA controller, if it is set to RAID, you will need a raid utility to format the SATA, or it wont shoe in windows, let ,e know
SOURCE: disk read error occured
If not give it a go and do a repair if needed again!
1- You may have a corrupt MBR (master boot record)!! You will need to reformat and do Fdisk /mbr to delete the master boot record!! Save all data first as this will not allow you to access any of your data as all file location addresses are located in the MBR!!
2 - Your harddrive may have a bad sector get a zerofill tool(low level formatting tool)!! This will rewrite you HD's sectors putting them back to factory spec's!! Maxtors is called Maxblast you can get it from thier site!!
3- or it could be a defective drive, but most read errors are due ot corrupt MBR or a bad sector!!
SOURCE: A Disk read error occurred upon booting
This could be a sign of the hard drive having a problem.
I would recommend that you do a scan of the hard drive to check for errors.
You didn't mention which operating system you have, but you need to click on My Computer and then right-click on your hard drive. Go to Properties and then Tools.
Once there, select the option that tells you to check the disk for errors. Check the entire drive. Note that this will not run right away. You must restart your computer, as the utility needs exclusive access to the hard drive.
If this type of error reoccurs, it's time to back up your data, 'cause you probably have a hard drive that is dying.
SOURCE: Unexpected I/O error has occurred--Status:Oxc00000e9
If you have error codes from the diagnostics, then your drive is failing or has already failed.
Check with Dell to see if you still have a warranty on it. It is covered, if your warranty is still in effect.
Booting to the CD requires that in the Boot Up (BIOS) that you have selected the CD as a bootable item - and that there is something to boot TO in the drive...
