It is a CFEF357GS3 stove.
SOURCE: frigidaire ceramic top self cleaning stove
Have you thought about reading the manual, it states that the heat goes off and on to maintain the proper heat while cooking, You should turn the burner off a few minutes before done because even on off the burner is still cooking while it is cooling down to go off. And you do not need to have as high of heat to cook that's what so great about this ceramic tops you save time and energy.
SOURCE: Stove top element overheats
HI thanks for your question. the problem is with the burner switch. replace the switch. thanks the appliance doc. please rate my answer. thanks
SOURCE: The bottom element stopped working
If the element is good then the problem must be the thermostat /switch is not working (a common fault) or you have a wiring fault which is rare. Check out the thermostat/switch controlling the bottom element and replace if necessary.
SOURCE: Front left dual element on a Frigidaire ceramic
open the door and look under the top remove the screws and the top will lift
SOURCE: FRIGIDAIRE STOVE MODEL FEF316BSC I WAS BAKING
Don't worry! Your element probably blew out. It's no big deal. It happens. Call us for parts. 9728590929. It's really a simple repair, probably one of the easiest to do. Hope this helps!
