On pump assembly page 30 in manual
https://www.northerntool.com/images/downloads/manuals/15781820.pdf
SOURCE: Oil for Comet pump
aftermarket oil will be fine just use same grade of oil,all manufacturers want that extra kick,
SOURCE: I have a northstar pressure washer with a comet
Normally, it is one of three things.
1.) The high pressure seals are bad
2.) There is debris in the check valves
3.) the unloader is stuck in by-pass.
SOURCE: what type of oil goes in a comet axd 3020 pressure
You should use what the pump manufacturer recommends. Typically a 30wt non-detergent (non foaming) oil. Do not over fill. If there is a sight glass half way is normal. Or if it has a dip stick follow the mark there.
Here is a great link for pressure washer parts and info
This link goes right to oil page:
http://pressure-washer-parts.com/shopdisplayproducts.asp?Search=Yes
