SOURCE: what size fuse do i need for amp
start with a 50, may need to increase it if you are not using a large capacitor.
600 watts = 12x
x= 600 watts / 12 volts
x = 50 amps
SOURCE: orion xtr15 to a american leagacy la 660 amp
your only choice is to run the amplifier at a 4 ohm mono load - this will not reult in the amplifier making much power.
Positive on sub to Positive on amp.
Negative on sub to Negative on amp.
This is your only possibility.
Adding a second sub in the same fashion will result in a 2 ohm load, and your amplifier will run at its rated potential.
Thanks for using FixYa - a FixYa rating is appreciated for taking the time to answer your FREE question.
SOURCE: what size fuse do i need with my 1200 watt 2
hey 25 watt thats wat i have got and mine is a 1100 watt..
