Page seven of a similar model manual
http://www.spectraintl.com/images/stories/pdf/jn/UM/JCR-310_EIB.pdf
1. With the unit in Standby mode, press and hold the TIME SET button for about 1 second
2. Press the (two right triangle / two left triangle buttons) to adjust the hour.
3. When the correct hour is selected, press the TIME SET button to confirm and the "minute digits" will begin to flash on the display.
4. Press the (twwo right triangle/two left triangle buttons) to adjust the minutes.
5. When the correct minute is selected, press the TIME SET button again to complete the setting.
SOURCE: Jensen MP5620
I dont know if this will work for the mp, but for my jensen 2010x ,while it is on, you press on the (disp) button for 5 seconds untill the clock starts flashing, then on the FF to set minutes and the rewind button to set hours. I literally spent 2 hours playing with it till i figured this out!!!
SOURCE: Set CD Clock Radio for Daylight Savings Time
I downloaded the manual from the Timex website give in a prior post.Here is a link to the manual in PDF: http://www.mediafire.com/?cn1kusjfosx
SOURCE: to set the clock on a jensen cd 2010x cd in car player
1. Press DISP for approx. 3 seconds until you see the clock flashing. 2. Use the up and down to change the values and the right and left (<< >>) to change from hours to minutes. Then hit the Disp to exit.
SOURCE: instructions for programming jensen jr 300 remote
I'm not sure if your remote will operate the vizio TV. You can try a code search and see if that works because the vizio TV is not listed.
Here is the user's manual.
SOURCE: setting clock on pioneer radio
you will need to turn unit off then press function button for a few seconds this will take you to the clock function.
Press T/F (7) momentarily to change the information displayed by the unit from mode-specific
information (radio frequency, CD track number, etc.) to the clock display. Press T/F again to
return to the default display.
The T/F button is also used to set the clock to the correct time. Press and hold T/F to enter into
clock set mode. When the time flashes on the display, rotate the volume control to adjust the
hours. When finished, press T/F again and rotate the volume control to adjust the minutes.
When no adjustments have been made for five seconds, the unit will resume normal operation.
You may also download the manual here:
http://www.jensenheavyduty.com/downloads/dl/file/id/96/vr185_owners_manual.pdf
