SOURCE: how to fix
It's a corona error, C200
First unplug the main charge corona take up motor as it may break the corona wire. next the wire is very thin and tends to oscilate out of control and cause the C0200 code. If a new wire spool, or grid doesn't alleviate this problem simply use electrical tape on the inside housing of the main charge corona assembly.
C200
There is a new part # for the charge corona. The old style has a problem with the wire cutting the block and breaking. The new ones have a brass post to prevent this. part# 1139-0313-01.
SOURCE: Copier Minolta model D1520
Remove the toner bottle and let the copier warm up to Ready, then re install the toner bottle and see what happens
SOURCE: Please Help Kyocera KM-1510 Grayscale Copier & Minolta D251 C0F32
check the exp.lamp . it mzay be blinking at the time of scanning the original.
SOURCE: I am using Sharp AR-M201 photo copier machine. I
F2 -02 Toner supply failure - Toner supply abnormality caused by
cause :-
- developer unit trouble
installation of unpacked toner cartridge
Hi abdull , I want to help you with your question, but I need more information from you. Can you please add details in the comment box? Whats the model number???????
