SOURCE: Owners manual
I have this cooker and manual. the manual got wet and I had to take it apart to dry it out. I decided to scan it and make a new copy since the original is pretty rough from getting wet & some pages stuck together. It is readable. I would be willing to share the manual, with anyone interested. I am scanning it now (about 54 pages) and plan to make it a PDF file. I would be able to email it to you, send you a CD or Print it out and mail it to you. All I ask is that you pay what it costs me for paper, ink or CD and postage if I mail it to you. No charge for the PDF by email since I am doing that anyway. I would never have found this forum, except I was looking for a manual to purchase before I went to all this trouble. I don't think there is one to be found. I will check this website to see if anyone wants the manual.
SOURCE: Manual Wolfgang Puck #BPCR0005
Here is the site for this pressure cooker and model # that you need...
http://www.wpcookware.com/manuals.asp
It's on the left hand side under the panini maker...the picture is of the 7.5 size but under that picture it does have a drop down menu that says model # and that 5 qt Pressure Cooker with that Model # is there...
Good Luck
Shelly
SOURCE: need pressure release device for wolfgang puck
Replacement parts for the Wolfgang Puck pressure cookers are available here:
http://www.wpcookware.com/categories.asp?cat=29
If you do not see the part you require or are unsure about the model number; suggest you contact their Customer Service at 1-800-275-8273 or via their webform at:
http://www.wpcookware.com/contact.asp
Sorry someone has not responded sooner, but just discovered this site.
SOURCE: displays E2 and E4 (5 qt Wolfgang Puck pressure
I think E2 means open circuit in thermocouple in center of bottom. E4 means no contact on pressure sensing switch at edge of bottom. Mine had E4 error. Took out switch and used fine sandpaper to clean contact points. Now it works fine.
Remove 3 screws in bottom. Remove bottom cover by turning it ~1/4" to clear tabs. Remove switch at edge of bottom with two blue wires going to it. Clean contacts and replace.
