Also like the previous comment or stated about the pressure switch, I don't know about that exact model for sure but a lot of times those pressure switches need to be reset on the back, because when they get over pressure it pops the safety which needs to be reset.
The condensate pipe must be piped into an interior drainage pipe or it will freeze. Turn off the red emergency burner switch to reset the boiler. Also make sure that your flue pipe is clear of snow and doesn't have residual condensate freezing up and blocking it. If it is not pitched back to the blr, it can freeze and clog the flue. This will cause your press switch to cut out on high pressure.
SOURCE: EA error msg on Bosh tankless unit
How I fixed it was got rid of it...support help never called back..and to get parts for it was looking into the new year can't go without a shower that long...can we now?
SOURCE: worcester boiler 2 years old keeps loosing pressure
http://www.worcesterbosch.com/Go there see if you can get some help.
SOURCE: hi where can i find a manual for a worchester
if you go on the worcester bosch web site and contact the service dept they should send one out to you or you may be able to download one from there.
SOURCE: Worcester combi boiler losing pressure & water through o/flow
having the same problem and its a new bolier. thanks , adriano.
SOURCE: pressure shows 0 psi greenstar 30si
open the water feed by raing the brass flat lever to 12 psi
