Question about Pride Health & Beauty
My pride celebrity x starts squeeking then grinding the battery monitor is bouncing back and forth the transaxle is hot and it quits can anyone give me an idea whats wrong
    Top Expert:
  • Pride Master
  • 62,003 Answers
IT IS WORE OUT PROBABLY FROM LACK OF GREASE . SORRY
Posted on Mar 06, 2019
SOURCE:
  • 68 Answers
SOURCE: temp gauge bouncing up an down
i would say if the fluid is full and the thermostat is not sticking it would be your engine coolant temperature sensor (ect) sensor
Posted on May 23, 2009
gewiz
  • 1367 Answers
SOURCE: pride mobility scooter. turn key on it keeps
Are you sure that it not in FREEWHELL mode, lever at the back, Regards
Posted on Jun 13, 2009
my-mobility
  • 9 Answers
SOURCE: Problems with Pride Celebrity X 4-Wheel Electric
It is often a damaged accelerator (Potentiometer). Sometimes the shaft on the wigwag breaks the contacts in the accelerator from being moved too vigorously when going over a bump too fast. A technician would need to repair this for you. Happy scooting. Regards Chris… info@mymobility.co.nz
Posted on Jun 22, 2009
  • 138 Answers
SOURCE: grinding loud noise in the transaxle
sounds like the bypass lever might not be re-engaging, push it in firmly. OR, the brake is sticking. this, of course, is if the noise is a growl or a groan. if it IS a grinding noise, look for something stuck in the trans cooling fan or between the axles and wheels, otherwise it's inside the trans and that's not good [re: replacement]
Posted on Aug 18, 2009
  • 175 Answers
SOURCE: pride celebrity deluxe comfortcoach 1v problem-
Usually when a scooter dies, there is an event that preceded the dead state that caused the fault. What were you doing before it went dead?
The biggest culprit for scooters and power chairs is moisture. With a scooter, there are two components most susceptible. One is located inside the top of the tiller and it is an electonics board about 6"x4" in size. If you had the scooter out in the rain without protection over the tiller, water can encroach into this area and short the board. Or, a coke or coffee spill can short it. There's a fuse on the board and if it is blown, then likely the board is shot as the fuse merely keeps the tiller from going into a total meltdown in the event of a short. Boards run about $25.00 to $45.00 to replace. Inspect it and look for any signs of overheating or corrosive buil-up and see if the fuse has blown.
The second component is located under the shroud beneath the seat. It is a small metal box which is the power control module and it controls all of the operations of the scooter. It has several wires going into and coming out of it (on-board chargers for some scooters will only have one wire going in and one coming out, sometimes two). These boxes are water resistant, but are susceptible to damage if the scooter has been run through a puddle and a lot of water has splashed up onto it. These are several hundred dollars to replace, but first check all of the fuses coming off the batteries that will lead from the battery to this control box and insure that it isn't a blown fuse. These fuses generally don't blow unless the scooter was operated beyond its capabilities, like driving it in sand, mud or other unstable terrain that puts an enormous strain on the motor and pulling a lot of juice from the batteries. Finally, check all of the connections that clip together. Don't rely on a visual inspection, take them apart, and reconnect them all to insure a good, tight fit.
Hope this helps.
Posted on Aug 28, 2009
What size batteries go into a celebrity x mobility scooter with four wheels
Pride Celebrity SC400 SC4001 Battery Replacement Kit
There is technical support offered at the Pride Go Go website. The site above simply offers a replacement. Further specifications may be obtained from them or a manual.
Pride Mobility CELEBRITY Owner Manual
Aug 12, 2017 | Health & Beauty
Can anyone help me? I own a pride celebrity lx8 scooter. It is beeping 3 and 1 or 3 and 2. What could this mean please? Many thanks R
Yes I done a quick search on the beeps it took me to the same fault codes as the book TRY SENDING AN EMAIL TO www.pridemobility.com.au....good luck..Hi again yes I just picked up the fault book and they call them flash codes I WILL CHECK INTO THE PROBLEM cheers. Hi 3 flash code unplug charger turn key of then back on again , 1 flash code charge batteries 2 code same as 1 charge batteries good luck
Jul 06, 2016 | Pride Health & Beauty
MY PRIDE CELEBRITY XL SCOOTER JUST STOPPED IT IS IN FREE WHEEL AND WONT ENGAGE IN TO GEAR
Sounds like a blown transaxle. If the scooter has had heavy use or a heavy rider this would not be uncommon after 3-5 years of use.
Mar 13, 2014 | Pride Celebrity Xl 4 Wheel Scooter
How do you remove the seat on a Pride Jett 2 electric wheelchair?
On all the pride chairs that I have worked on, you just rotate the seat from straight ahead a little to unlock it, and then pull up while turning it back and forth.
Jan 02, 2009 | Pride New Mobility Celebrity 3 wheel...
Health & Beauty Logo
Top Pride Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
