SOURCE: Jabra 250 Codes
To make this complete: You need to turn off the headset (hold call button several seconds until it makes descending tone). Then hold button to turn on and keep holding 8 seconds more until blue light is on solid. Then initiate pairing at phone, and enter 0000 as the code.
SOURCE: I lost the instructions. I want to pair my Jabra
1. I have the Jabra 125. You can get the manual at www.jabra.com if you have a different one.
2. Turn off your phone. Power off. The order of powering on devices is the key.
3. Press and hold your Jabra power button until it's glowing blue (not flashing blue light--but constantly on)
4. Then turn on your phone...and look for wireless devices in your phone menu.
5. Make sure you have bluetooth turned on.
6. the phone will find the Jabra, and then will ask to pair with it. passcode is 0000.
7. That's it.
Again, the key is the order of turning on devices.
Thanks.
SOURCE: Lost Pairing instructions for Jabra Earpiece CE
Go to this site, and it will walk you through each step to connect your
particular Jabra headset with your cellphone. Choose the headset, and
then at the next page, choose your phone. Moving your mouse over each
step will change the picture to what you should be seeing on your phone
at each step.
http://jabra.pairx.co.uk/ Pls come back and let us know if this solved your problem.
SOURCE: I need pass key for
It all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device.
Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
Take care.
SOURCE: I'm trying to pair my Jabra GNM-OTE3 with my
Hello sir, honor to make you know that GNM-OTE3 is not a valid model of jabra products. try to identifie your product first you can post a photo for it and I can help you in the future. Bye
