Press and hold the keypad with the padlock icon until you hear a beep. This should be about 3 seconds. This will toggle the lock on and off. I used the documentation for the Frigidaire FGIC3067MB to check this. On this model, the lock keypad is to the left of the Keep Warm keypad. https://www.frigidaire.com/Kitchen-Appliances/Cooktops/Induction-Cooktops/FGIC3067MB/ . The manual is here: http://manuals.frigidaire.com/prodinfo_pdf/Lassomption/318205604en.pdf . The control panel is shown on page 5 and the lock function is shown on pages 6 and 9.
I hope this helps.
SOURCE: the lock on my thermadore hybrid induction cooktop
try turning off the breaker for at least 5 min and re apply power. If this doesn't work, then there's an internal problem.
SOURCE: my induction cooktop is locked and won't unlock.
either control panel or keypad has gone bad.
SOURCE: 30" wolf induction cooktop and it is locked in showroom mode
Hiya, hold the child lock button for 3 seconds. should unlock. Best of luck
SOURCE: Wolf Induction cooktop is locked in Showroom mode
If Shr (5hr) appears on the display then the cooktop is in showroom mode. To exit showroom mode the cooktop must be locked by pressing and holding the key symbol for 5 seconds. After the cooktop is locked, press and hold the melt touch pad for 5 seconds.
SOURCE: whirlpool induction ceramic cooktop error E6
my induction ceramic cooktop is showing an error code E6 on two of the elements...what is the problem and how do I get it fixed
Thank you for your post, friend!
I located that on Electrolux Cooktop error codes "35" and "75" stand for input voltage too low. It could be an issue with your filter board or an issue within the voltages. I would recommend having a professional come out to your cooktop to properly diagnose to avoid any unnecessary part purchases. -Matt
