Question about Pride Jazzy Select 6 Indoor Power Wheelchair
What type of screwdriver will I need to take apart a two key gc joystick for a jazzy scooter? I want to replace the “power” keypad. It looks like a very small “star” screw.
    Top Expert:
  • Pride Master
  • 62,042 Answers
THEN YOU NEED A STAR SCREW DRIVER NORMALLY THOUGHT OF AS A TORX SCREW DRIVER
Posted on Mar 06, 2019
5 Suggested Answers
SOURCE:
SOURCE: broken GC controller
yes you can. but only though the internet.
Posted on Mar 08, 2008
dromtonpa
  • 40 Answers
SOURCE: problem with joystick on Jazzy 1103 ultra
You will need to take it in for repair. 8 bar flash usually means you have a bad joystick/controller. They can sometimes send it in to the manufacturer to have it repaired. Find a reputable dealer and relay this info to them.
Posted on Apr 01, 2009
  • 16 Answers
SOURCE: i cant see where to plug in jazzy power scooter
Under your Control Panel with Joy Stick there is in Small round port hole , and this is where you Charge your Chair, You will when you look under the front of this panel the hole with (3) Pins Connect here, and good Luck,
Gerry.
Posted on Jul 12, 2010
  • 692 Answers
SOURCE: need new joystick controller for Jazzy 1103 ultra mini
Who bought the chair you or Medicare? If Medicare they will pay for most of the repair cost Contact Repair Xpress at 1-877-581-3733
Posted on Aug 17, 2010
WHEN POWER ON CHAIR SPEED LIGHT BLINK .BOTH BATTERY WAS REPLACE AND JOYSTICK.SAME PROBLEM
The battery meter lights will flash a flash code when something is wrong. If the lights are flashing the same number of lights each time. get that number it is a flash code. if the lights are cascading up and down that indicates that the Joystick is locked. unlock by turning on the joystick and pushing the horn button twice within 10 sec. of turning on. Or push on button and hold the joystick gimbal forward until it beeps then back until it beeps. This should have it unlocked, if not Pride Jazzy Tech 800-800-8586
I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_bcbb89783b08c489
Mar 28, 2016 | Pride Mobility Used Power Chairs Jazzy...
How do I replace the throttle potentiometer?
You don't you, replace joystick. However, should you take the joystick apart you may have many hours of intense frustration awaiting you.
Jan 20, 2016 | Pride Jazzy 600 JAZZY 600
100%charged select Elite- What is procedure to start power on / off?
Sounds like the switch itself.. the black button.. is defective. Best case is, the Pride dealer that sold the chair will fix it. If they sold the chair to you, and billed insurance to pay for it, they should bill insurance to pay for the repair. Call the dealer.
If you're on your own, you need to find the part. Does this look like it would fit?
http://www.monsterscooterparts.com/keypad-2-key-gc-joystick-jazzy-select.html
Feb 15, 2015 | Pride Jazzy Select 6 Indoor Power...
Speed fluctuating on controller. goes from slow to fast without me touching controller on pride jazzy 614 hd battery powered chair
Your controller is dirty. Unfortunately, the unit is sealed and you therefore can do other than replace the unit. I suggest monster scooter parts at Jazzy 614 HD Parts The cost is high at $377.00. If you were really into fixing electronics it is possible to take the unit apart and clean the joystick, but that is a stop gap measure until you get your new joystick. Let me know if you need instructions on tearing the joystick apart and I will help if I can.
Jul 22, 2014 | Pride Jazzy 614 Hd JAZZY 614HD
Everything works fine but won't manually turn off, but will time itself off.
There are two possible likely problems here: the joystick "key" or contact on the printed circuit board is bad/worn or the joystick is defective. The "key" is the rubber button pad that you press to turn the PWC on and off. This keypad is carbon embedded rubber that makes contact on the printed circuit board underneath. When these age or get moisture, the contact on the board oxidizes and the rubber becomes de-carbonized resulting in a poor contact when the key is depressed. Cleaning the contact with rubbing alcohol and a light scraping tool works sometimes. Replacing the keypad is a must.
If these don't work then you have a bad circuit board in the joystick. Either replace the joystick or the PCB within it. PCB replacement must be done by a properly trained electronic tech or Curtiss\PG Drives who makes the joystick.
Mar 16, 2014 | Pride Jazzy 614 Hd JAZZY 614HD
Have a jazzy chair purshased from scotter store. error code flashes 8 times. cant get anyone to come look at it what do i do?
If you have a GC Controller 8 flashes indicate a control system fault. Check all connections - especially connections to power module and joystick.
Apr 19, 2013 | Jet 3 Ultra Power Chair
Jazzy Select controller on-off switch (push button) very difficult to operate. Must push button down with much force to get it to work. Can I get the controller apart without ruining it?
The display on top of that joystick controller is essentially a fancy decal. it can just be peeled off. Usually when the symptom you're describing is happening it is because the button on the underside of the decal is wearing out. This can't be fixed. The joystick face must be replaced. However, you should be able to get this from a certified Pride dealer for 60 or 70 bucks versus several hundred for a new joystick controller.
Mar 27, 2013 | Pride Mobility Jazzy Select Wheelchair -...
I have a Jazzy 1121 wheelchair and need a face plate for the controller. The ss# is J40355044020. Where can I find one?
Contact Pride Mobility @ 1800-800-8586 ask for Jazzy tech support and ask if you can order a faceplate for your joystick Hope this helps you
Jun 16, 2011 | Pride Jazzy Select 6 Indoor Power...
I need to know how to lock the Jazzy 1200 when out in public and not in use.
See below Hope this helps you
To lock the VSI:
1. With the VSI powered on, press and hold the on/off key. After one (1)
second, the VSI should beep.
2. Release the on/off key.
3. Push the joystick to the full forward position until the VSI beeps.
4. Pull the joystick to the full rearward position until the VSI beeps.
5. Release the joystick. There should be a long beep.
6. The VSI is now locked.
May 08, 2011 | Health & Beauty
Broken GC controller
Mar 07, 2008 | Video Game Consoles & Games
Pride Jazzy Select 6 Indoor Power Wheelchair Logo
76 people viewed this question
Top Pride Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
