Is Optimus radiator light suppose to go on & off? Got at yard sale
Not sure what your model number but following is for H-6003.
Search "optimus radiator manual"
OPERATING INSTRUCTIONS:
Plug the power cord into a wall outlet
(110-120V AC, 60Hz)
This heater has only one (1) power setting, pressing the
rocker switch to the ON position, it will give you 700 watts
of heat. When you want to switch off, then just press
the switch to the OFF position.
When the unit is turned on the power indicator light will
illuminate to tell you that the heater is functioning.
THERMOSTAT INSTRUCTIONS:
Before setting the thermostat, allow the heater to operate
and warm up the room. You need to set the thermostat
on MAX to start the heater.
When the desired temperature/comfort level is reached,
lower the thermostat setting until the heater stops
operating.
The control will now automatically maintain the pre-set
temperature level by turning the heater ON and OFF
