Question about New Bright Big Foot 114 Scale Radio Control Monster Truck with Battery Pack and Charger 49MHz Raminator Red
Jets on foot bath
The jets no longer work.
We have gunk coming from the jets when powered on - What's the best way to clean this tub so we can actually use the jets?
You need to use them on a regular basis. Put as little water in the tub as you can get away with and then add some bleach. Run the bath jets for 15 minutes to clean and sterilise it. Empty the bath and fill it again with plain water. to rinse it.
Feb 25, 2018 | Jet Home
Morgan spa diagrams
The water jets in most spas are adjustable so you can turn the water flow down to just a trickle if you want to.
You don't take current spa jets out of the spa. They are held in place by a couple of tabs. Through the years the chlorine/bromine will deteriorate those tabs and the spa jets will start "popping" out when the jets get turned on.
If you pull the jet insert out the socket they are in, you will ruin the jet insert and it will need to be replaced.
Rod
US Parts Center Bath Spa Replacement Parts Hot Tub Bath Parts Accessories US Parts...
May 13, 2014 | Pool & Spa
Galbocca bathtub with jets
I have galbocca jet tub which is no longer working. I live in Lawton, ok. No one works on them here. Any suggestions?
Aug 22, 2013 | Whirlpool Home
How to start the jets on an MTI FURO MTDS 59
Checking the circuit breaker for power to the pump is obvious however the control that turns the bath pump on/off may be the real problem.
MTI has what control box to operate the pump?
Check there first because that may be the problem before the bath pump is a problem.
We would need to know the model number of the bath pump and the control box if there is one that the bath pump plugs into.
Rod
US Parts Center
888-521-6183
Mar 11, 2013 | MTI Furo MTDS-59 AST59
Maxx jetted tub quit pumping water, pump motor just races.
When the bath pump runs and you get no water going through the jets in your bath Jet trim then the impeller has probably spun off the shaft of the motor.You will not know if this is the case until you take the bath pump out and remove the front cover of the bath pump and check the impeller.If this is the case it usually has to be replaced.
Rod
US Parts Center
888-521-6183
Feb 22, 2013 | Home
I have a homedics foot bath with water jets and no instructions. Can I use epsom salts in the foot bath?
According to the manufacturer it is not recommended you use Epsom salt in this product as long term use can cause corrosion to the water jets. I hope this helps.
Jun 22, 2011 | Health & Beauty
I have a marble jet bath tub. is there anyway to cap the jet holes, so it is no longer a jetted bath?
You should be able to remove the access panel and just disconnect, and cap the hose that is connected to the pump for the jets and then cap the pump nipple, where the hose connects.
This would likely be easier than trying to locate multiple caps to plug the jet holes in the tub.
I hope this helps you.
Feb 02, 2011 | Jacuzzi - Bathtub - Alcove - Navona -...
I know I can take a bath without turning on the jets. However; does the bath water with soap flow back into the jets? I like bubble baths, If I leave the jets off can I use the bubble bath without having...
The soapy water will fill all of the jets, tubes and the pump assembly. Will it hurt the tub if the jets are not running? The soap film will build up in the jets, tubes and pump assembly and can possibly cause damage if the tub is run at a later date. Contact the tub manufacture and see if there is a safe bubble bath you can use.
Aug 23, 2009 | Jacuzzi - Bathtub - Alcove - Navona -...
Whirlpool bath jets
open the side panel and there will be a sticker on or near the pump with all the info
Dec 23, 2008 | Whirlpool Safety Bath Walk In Bathtub -...
New Bright Big Foot 114 Scale Radio Control Monster Truck with Battery Pack and Charger 49MHz Raminator Red Logo
26 people viewed this question
Top New Bright Toys Experts
Colin Stickland
Colin Stickland
Jonah Oneal
gerry bissi
Are you a New Bright Toy Expert? Answer questions, earn points and help others
