Question about Refrigerators
How to replace lights on refrigerator LFC25760SB
    Novelist:
  • 91 Answers
In the LG bottom freezer refrigerator (model LFC25760SB), the light bulb covers inside the refrigerator and freezer compartments are attached using friction-fit clips.
It will be safest to unplug the unit, or shut off the circuit breaker. You may also need to remove Items, including the top 1 or 2 shelves.
Push the front of the cover gently toward the back of the refrigerator; LG's instructions show a screwdriver, but I would use something more flexible like an expired credit card or emty gift card. Swing the cover down to unhook the clips at the back.
Be careful with the bulbs, as they can get very hot, particularly if it takes some time to clear the way to the cover and get it off. I would close the door and wait a few minutes to let the bulbs cool off before removing them.
LG has a downloadable manual on their website that shows the procedure and gives the bulb specs (60 watt appliance type).
https://www.lg.com/us/lgecs.downloadFile.ldwf?DOC_ID=KROWM000110253&what=MANUAL&fromSystem=LG.COM&fileId=KROWM000110253.pdf&ORIGINAL_NAME_b1_a1=3828JD8991B%28ENG%29.pdf LG LFC25760SB Support Manuals Warranty More LG
Posted on Feb 28, 2018
SOURCE:
Replace lamp in Westinghouse RJ390P refrigerator
Refrigerator Repair - Replacing the Light Bulb (Frigidaire ...
? 1:39
https://www.youtube.com/watch?v=7yE0ZZBNISU
Nov 8, 2012 - Uploaded by PartSelect
Refrigerator Repair - Replacing the Light Bulb (Frigidaire Part # 5303013071) ... Kelvinator, Tappan, White ...
Refrigerator Light Bulb (part #5303013071) - How To ...
? 1:23
https://www.youtube.com/watch?v=1AQTDSn4VFw
Dec 20, 2013 - Uploaded by AppliancePartsPros
Follow these simple step-by-step instructions to replace theRefrigerator Light Bulb 5303013071 on ...
Jan 14, 2016 | Westinghouse Refrigerators
GE Monogram ZV950S D2SS range hood - lights on one side stopped working then on both sides. This happened as I was changing bulbs. Everything else works.
Light doesn't work
  1. Light bulb
If your refrigerator light does not power on, the first thing to replace would logically be the light bulb itself.
  1. Light assembly
If your refrigerator light does not power on and you have replaced the bulb, this is an indication that the light assembly may have malfunctioned and will require replacement.
  1. Light switch
If you notice that your refrigerator lights are not working, replace your refrigerator light bulb. If this does not correct the issue, proceed to check the power light switch.
  1. Door switch
If your refrigerator light is not working and it is not the bulb itself or the power light switch, the next thing to check is the door switch. This can be checked for continuity with an ohm meter. If there is no continuity present, the door switch will need to be replaced.
  1. Light socket
If your refrigerator light is not working after replacing the light bulb, check for a possible damaged light socket. If the socket is faulty, replace the part to get your refrigerator light to power on again.
  1. Light board
If the refrigerator light is not working the light board could be defective. The LEDs on this board are not repairable, so the entire board will need to be replaced.
Feb 15, 2015 | GE Refrigerators
LG LFC25760SB
Sounds dangerous and a fire hazard. Unplug it until you find the fault with the unit or replace the fridge.
Oct 11, 2017 | LG Refrigerators
How to change light bulb in refrigerator
Unplug the Whirlpool refrigerator from the electrical outlet.
Step 2
Locate the bulb on the inside of the Whirlpool refrigerator.
Step 3
Remove the light cover. Usually these just snap off, but, on some models, they may need to be unscrewed. Use your screwdriver to unscrew the light cover retaining screws (if required).
Step 4
Unscrew the old light bulb.
Step 5
Screw in the new light bulb.
Step 6
Replace the light cover. Plug the Whirlpool refrigerator back in. Test your new light bulb.
Also note that the below can also work
Unplug refrigerator or disconnect power.
Slide the light bulb cover toward the back of the compartment to release it from the light assembly.
Replace burned-out bulb(s) with appliance light bulb(s) no greater than 40 watts.
Replace the light bulb cover by inserting the tabs on the cover into the liner holes on each side of light assembly. Slide the cover toward the front until it locks into place.
NOTE: Do not force the cover beyond its locking point; doing so may damage the light cover.
Plug in refrigerator or reconnect power.
To change the freezer light bulb:
NOTE: You may need to remove the upper freezer shelf or basket to access the light assembly.
The light bulb cover opens from the back. Firmly press forward on the notches in the back of the cover and pull down the cover.
Remove the cover and replace the burned-out bulb with an appliance bulb no greater than 40 watts.
Insert the front tabs of the cover into the liner and snap the back portion of the cover over the light assembly.
Good luck in applying the solution
Jul 29, 2010 | Whirlpool GX5FHTXVA Bottom Freezer French...
LG french doors, bottom freezer. Water leak from
Make sure your ic maker is empty. On the bottom of the ice maker is a small button. Watch the plastic fill tube and hold the botton in. Let the ice maker cycle anmd see if the water over shhoots rne ice maker. If it does, trim 1/8 of an inch off of the tube with a raxor knife on an angle = / this should take care of your problem.
Jan 14, 2010 | LG LFC25760SB 25 Cu. Ft. Panorama French...
The light bulbs inside my LFC25760SB are staying on constantly, even with the doors closed. In addition to warming the food, this has also caused melting of the plastic parts surrounding the bulbs. I can...
You have a bad main board with a relay stuck shut. Call an LG dealer and ask them if there is a service bulliten on your model. If there is, your parts are free.
Dec 20, 2009 | LG Refrigerators
LG LFC25760SB french door light off but hot
try to replace the bulb/ door switch
Nov 13, 2009 | Refrigerators
LG Bottom Freezer Frost Issue
It sounds like your defrost controller has gone bad. I have an LFC25760 and had ice build up in the bottom of the freezer such that water would start leaking onto the floor. The ice build up in the bottom of the freezer was due to a failing/bad defrost controller. Behind the back white wall in the freezer compartment exists the cooling fins along with a heating element underneath. Due to moisture that comes into the freezer from opening it, frost/ice builds up on the cooling fins. Thus the defrost controller turns on the heating element to melt the ice/frost off of the fins which then drips into a metal pan which channels the water to a drain hole which drops into the drip pan underneath the fridge next to the fan. The problem is that the defrost controller doesn't keep the heating element on long enough or the cooling cycle comes on too soon thereby freezing the water and plugging up the drain. I had my defrost controller replaced (just outside the warranty period!) and it worked for about 1-month and then same thing happened again. Instead of paying for another defrost controller that would probably not work 100% my serviceman used the old paper-clip trick. He took a paper clip, stretched it out and then wrapped one end around the heating element and placed the other end into the drain hole. Thus when the heating element comes on the paper clip keeps the drain hole warm/hot and prevents the water from freezing. It has been 9 months since this fix and I haven't had any ice pooling in bottom of the freezer.
Jun 22, 2009 | LG LRFD25850 French Door Refrigerator
Refrigerator Lights Stayed on, Melted Plastic and Stopped Cooling
The control board relay switch for the light bulb stuck in the on position and needs to be replaced along with the light cover and housing.  There is also a replacement light harness that has a high limit switch to shut off the lights if this happens again.  LG knows about this problem and if you call LG customer service, they will grant a one time warranty extension to take care of this problem.
Jun 09, 2008 | LG LFC25760 French Door Refrigerator
Refrigerators Logo
238 people viewed this question
Top Refrigerators Experts
Marvin
Marvin
Gil Shultz
