Question about Krups KM7000
Water will not drop to make coffee....
Krups model KM7000. water will not drop through to make coffee....when I press the on button I can hear a click but it will not brew....
    Scholar:
  • 22 Answers
I your plate is not heating, no water will flow. This seems to be a common problem with this rig. So far, I've helped 13 people on this site with exactly the same problem ... all the lights are on, but no heating on the plate and no dripping water.
After a weekend on the workbench, I've mastered this machine. The KM7000 has 2 x MicroTemp G4 thermal cutoff (TCO) fuses which interrupt the Live line, for overheat protection. Mine didn't overheat per se, but the TCO blew anyway. Not reset-able ... need to be replaced with a soldering iron. I'll be happy to advise you to fix this, or fix it for you. Write me at KM7000@flightsystems.biz
Posted on Jan 31, 2010
  • 86 Answers
Water passes through the tube inside the system which uses electric current to produce heat and pushes the heated water out. check if there's clogged material in its passage
Posted on Jul 31, 2009
SOURCE:
I set up our new coffee maker and it didn't grind...ordered it online from Macy's but had no manual and didn't know what to do...put coffee grinds in the top and then set up the timer for this...
You need to swivel the brew basket cover until it locks for the coffee to grind. Then turn the machine on and the coffe will grind. , then turn the machine off, add water and press the auto on to use the auto timer.
Dec 13, 2009 | Krups KM7000
Krups KM7000 grinds but won't brew, warming plate no heat. Is this repairable, (perhaps a fuse?) or is it junk. Bought the machine in March 2008
Mine had the same problem ... all the lights are on, but no heating on the plate, and no dripping of water.
After a weekend on the workbench, I've mastered this machine. The KM7000 has 2 x MicroTemp G4 thermal cutoff (TCO) fuses which interrupt the Live line, for overheat protection. Mine didn't overheat per se, but the TCO blew anyway. Not reset-able ... need to be replaced with a soldering iron. I'll be happy to advise you to fix this, or fix it for you. Write me at KM7000@flightsystems.biz.
Oct 30, 2009 | Krups KM7000
My Krups Grinder Brewer has stopped pulling water though the system. It just stays in the resevoir. Grinder part seems to be working fine.
Oct 09, 2009 | Krups KM7000
Krups KM7000 won't brew
Your heating plate is your hot water heater, and most likely failed. Krups replaced my whole unit.
Oct 07, 2009 | Krups Coffee Makers & Espresso Machines
KRUPS KM7000 POWER IS ON AND IT GRINDS BUT DOES NOT BREW THE WATER TO MAKE COFFEE.
Check to see if your heating plate warms up, if it doesn't then your water heater/heating plate has failed.
Oct 02, 2009 | Krups KM7000
Krups KM7000
Check to see if your heating plate heats up, if it doesn't then your water heater/heating plate has failed.
Sep 08, 2009 | Krups KM7000
Same thing here. It was working one minute, and then is wasn't.
Check to see if your Duo filter is clogged, and after you remove it see if there is an obstruction beneath it. Sometimes people drop coffee beans in it.
Sep 04, 2009 | Krups KM7000
Got a Krups KM7000. Coffee grinds but no water to brew coffee.Just clicks. then nothing. Tried to reset by unplugging but no help. Grinds everytime even when it's not supposed to. Water will not dispense.
This seems to be a common problem with this rig. So far, I've helped 13 people on this site with exactly the same problem ... all the lights are on, but no heat on the plate and no dripping water.
Aug 24, 2009 | Krups Coffee Makers & Espresso Machines
Km7000 will not brew
Your heating plate/water heater has failed. Krups replace my whole unit.
Aug 15, 2009 | Krups KM7000
Krups KM7000 Logo
694 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Pierre Laplante
Ray Murphy
Marvin
Marvin
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
