Coffee Makers & Espresso Machines Logo
j
judith raudino Posted on Feb 27, 2018
My delonghi maginifca s has the descale button flashing after the descale is finished
Robert North
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on Jan 11, 2019
Robert North
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
31702
Points
9
I have the same problem. I think it's a factory defect. The descale button doesn't work, and it's never been descaled. I just leave vinegar in the machine overnight and run water to rinse it the next day. Vinegar is just dilute acetic acid. Citric acid works better than vinegar, but it's harder to find. It doesn't have the smell that vinegar does.
3 Related Answers
Anonymous
  • Posted on Jul 08, 2010
SOURCE: descaling a delonghi magnifica ESAm04
I had this problem too. The instruction manual says to turn the steam knob only half way counter-clockwise after pressing the button for 5 seconds, but you need to turn it ALL the way to have the procedure start (at least, that was the solution with my machine). Good luck!
Anonymous
  • 490 Answers
  • Posted on Sep 12, 2010
SOURCE: needs descaling. Can I use
Yes, the DeLonghi product will work well in your machine, no fear:)
Farmerbear at FixYa.com
robertpnorth
Robert North
  • 3 Answers
  • Posted on Apr 04, 2017
SOURCE: delonghi magnifica eam 3200 won't descale
I have the same problem. The descale cycle won't start when I hold down the descale button. It just keeps blinking. I've just been running vinegar through it, and hoping that it removes the lime. I think the button is just bad, or the computer is bad. It seems like a factory defect because the descale cycle hasn't been done enough to wear out the button.
There is a flashing steam light on our Delonghi Espresso maker and it won't go off even after descaling
Explanation of lights
When the appliance is turned on Flashing lights: the appliance is heating up to make coffee Lights on steadily: the appliance is ready to make coffee The lights flash rapidly: the tank is empty or the appliance will not make coffee. See the section "2. Filling the water tank" 3.
https://www.delonghi.com/Global/countries/se/Manualer/0132106141.pdf
https://cremacoffeegarage.com.au/blog/delonghi-coffee-machine-troubleshooting-descale-light-message-wont-turn-off
I have a DeLonghi EC860.M that will not descale.
Descaling
  1. Remove the water filter. Fill the tank with the descaling. ...
  2. Insert the hot water spout (fig. 8).
  3. Place one container under the boiler outlet and one under. ...
  4. Simultaneously press the. ...
  5. Press the. ...
  6. Once the descaling solution is terminated, the light. ...
  7. To eliminate the solution and lime scale residues, rinse the. ...
  8. Press the.
https://www.manualslib.com/manual/594778/Delonghi-Ec860.html?page=14
2answers
Delonghi magnifica has exclamation
Switch the machine off, AND pull the plug, wait 5 minutes (to be sure) and turn it on. Then turn it off again, now the infuser should return to it's normal position where you can take it out.
If the descale button is still flashing, try descaling again. Was the procedure interupted before? That would be a reason the light keeps flashing.
Bert
My delonghi ec860 red light keeps blinkin when coffee finishes coming out what does that mean.
Robert is it the light that has two signs underneath, if so then it is time for descaling.
kolbrun
3answers
Descale eam3400 delonghi magnifica machine
Hi, you need to select descale procedure from menu options and then add descale solution usually 100-125ml to 1l of water to your tank. Also you should find this how to do in instruction manual.
How to descale the DeLonghi Esclusivo Magnifica ESAM3300 Espresso Machine
put your descale mixture in 1 litre water in your water tank on coffee machine set machine on descale then after finish, put 1 litre clean water for rinsing. the all ready for coffee.
1helpful
6answers
I have a Magnifica. The descale red flashing light won't reset after going through the descaling procceedure.
I have the same problem with my Delonghi Magnifica, so maybe there is a glitch in the machine..
16helpful
2answers
Descaling a delonghi magnifica ESAm04
2answers
Delonghi magnifica eam 3200 won't descale
we are encountering some connection problem that's teh reason why our converastion are always in cut.
if you read this let me know here i can help you to solved your problem.
thanks,
Top DeLonghi Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
Kolbrun...
Paul Bade
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
