Question about Hitachi Tools & Hardware - Others
Hi I have a hitachi gas strip nailer it doesn’t fire I have changed the spark plug and checked the adapter the adapter is ok the spark plug is new but still not firing is ther anything else I can do any information would be appreciated Thank you Danny
    Sergeant:
  • 234 Answers
The number one issue is bad fuel - even if you just purchased it, turn the cell over and check the date stamped on the bottom (often stores don't rotate their stock)
If the fan starts when the nose is depressed but there is no spark then I would investigate the spark wire (make sure there are no nicks or cuts that may short to ground) and the ESU (Electronic Spark Unit).
Posted on Feb 02, 2019
SOURCE:
SOURCE: Coleman6250 Generator PM0545007 - Won't start/run.
Most gasoline engines need three basic things to run: proper air/fuel mixture, sufficient compression, and a properly timed spark. Check the easiest, cheapest things first, then check the "Gee, I forgot to turn on the gas" kind of things next, then work your way onwards from there.
Compression can be guesstimated with the proverbial thumb-over-the-empty-spark-plug-hole routine as you turn it over casually to check compression. If it doesn't blow your thumb out of position, you could have a hole in the piston (overheating response) or a stuck or damaged intake or exhaust valve.
Check for fuel flow by carefully disconnecting the fuel line to the carburetor and letting some run into a tin can (no styrofoam coffee cups, please). It should dribble freely. If not, you have to back-track the line and find out where the blockage is.
Spark is one that sounds like you've already tested (spark plug out of the cylinder head, hooked up and laying on the metal engine as you turn it over?) so check timing. You will probably need a manual for this test, although a good estimate is that the plug should fire just a wee bit before Top Dead Center position of the piston. Like I said, a manual comes in handy here.
From what you've mentioned, though, I'd start trouble-shooting at the fuel flow part first.
Good luck,
GRB
Posted on Jun 08, 2009
  • 3 Answers
SOURCE: brand new , won't start, no spark at plug, switch ok
check the spark plug and see if it is getting fire if not replace the spark plug if that dont work take it back.
Posted on Jun 24, 2009
  • 24 Answers
SOURCE: NAILER WONT FIRE NAILS
DO NOT USE WD40 . Is The Nailer fireing? If Not check the micro switch by the fan . Make sure it is pushing on the switch.. Otherwise bend it a little
Posted on Jul 07, 2009
  • 174 Answers
SOURCE: Honda Pressure Washer HP 5 not starting
You can try spraying some carburetor cleaner into the carb. If it starts for a minute, your carburetor need cleaning. When you added new gas did you remove the old gas first? Is the air filter clean?
Posted on Jul 19, 2009
  • 50 Answers
SOURCE: my hitachi nailer wont fire
Start with the basics:
First check that the butane (or whatever gas is used) canister is full. If empty, put in a new one.
Second check to make sure your battery is fully charged to be able to fire the spark to work the nail gun. If not get the battery charged and/or replaced as needed.
Third make sure all of the safeties are working properly and that you have them engaged to the piece of wood you are nailing when you try the trigger.
If beyond that it does not work it could be a bad trigger, a bad safety switch, or even a bad connection from the battery to the device.
Posted on Nov 01, 2009
Hitachi nr 90 gc2 nailer wont fire
Various reasons, secondary switch faulty. gas out of date, gas is colld, iar leak, faulty spark unit.
Suggest you get it checked out at a repair centre.
Jan 04, 2013 | Hitachi NR90GC2 Cordless Gas Clipped Head...
My hitachi nail gun NR90gc2 will not fire
Check the date of the bottom of the gas. With the gas removed when you fire it you should hear a faint spark sound from the top. If gas is in date try putting it in your pocket for 10 minutes to warm it up. Open the front and make sure the piston is pushed all the way up into the machine.
Nov 17, 2012 | Hitachi NR90GC2 Cordless Gas Clipped Head...
My hitachi nail gun just fire one time and the piston stay out
This is most likely caused by the band (or o-rings) on the outside of the cylinder. It could be a trigger valve problem, but the fact that it doesn't come out until the trigger is pressed points to the cylinder rings.
Apr 22, 2012 | Hitachi 3 - 1/4" Framing Strip Nailer
Nail gun will not fire the nail. Compressor works fine. Hammer doesn't retract enough to hit nail? Cause, solution?
could be a jammed nail in the magazine nose area, bent driver blade or problem with the o ring being worn.
Jun 06, 2011 | Hitachi NR90AD 3 - 1/2'' Clipped Head...
My hitachi nailer wont fire
Nov 01, 2009 | Hitachi NR90GC 3 1/2" Gas Powered Clipped...
Paslode 350 wont fire
Probably needs cleaning. You`ll need two new o`rings.
Aug 19, 2009 | RTO PasLode 900420 Impulse Framing Nailer
Sparks when shooting a nail
It is common to see sparks. It is metal striking metal. Although, if it sparks alot. It could be a chipped driver blade and the nail would not drive all the way. Does your sink `em?
Aug 15, 2009 | Hitachi NT65MA2 1 1/4 To 2 1/2 Inch 15...
Intermitent firing
Hi .I had the same problem with my gun,have you tried taking the fan housing off and cleaning the sparking point then oil and reassemble this seemed to wok on mine
May 03, 2009 | Hitachi NR90GC 3 1/2" Gas Powered Clipped...
CLEANED NAIL GUN EVERY THING SOUNDS OK BUT NOT FIRING CHANGED GAS
Pull the top off and clean the spark plug with a carb cleaner spray.
Check gas canister ...make sure it's not empty..
Do you get a green blinking light on the unit?
K
Apr 10, 2009 | RTO Paslode 902000 IM250 Ii Cordless 16...
Tools & Hardware - Others Logo
145 people viewed this question
Top Hitachi Tools & Hardware - Others Experts
John Trevino
Lance Guthrie
Lance Guthrie
Level 1 Expert
Roger Paull III
Are you a Hitachi Tool and Hardware - Other Expert? Answer questions, earn points and help others
