Hi there, are you sure it is not a number password ?? sim digits
http://www.packardbell.com/pb/en/GB/cont...
best is to ask PB this
no pc stated at all 1 year ago.
its PC computer not Cell phone.
no SIM
the PC has 7 levels of Passwords...
if this is PW lock isssue?
NO PC EVEN STATED,JUST COMPUTER .
NO DEAD SCREEN PHOTOS POSTED
SO IS HOPELESS.
SORRY WE CANT GUESS PC HERE
No even a link to your reviewed by say Cnet.
not even laptop ,desktop or year made.
wiki says
Packard Bell products are sold in Africa, Europe and the Middle East.
this PB from 1995?
WHY PB ONLY MEANS ALMOST NOTHING AT ALL.
circa 1995 sold in USA
Compaq sued Packard Bell
for this PC , BELOW.
history matters. as does locations.
we are a USA forum fixya
if you not in the USA it be best to say where
and what PC you have."MODEL"
2ND PB OWNER:
In 1999, NEC began withdrawing the Packard Bell name from the U.S. market, while keeping it in Europe, where the brand was untainted by allegations of sub-standard quality.[9]
3RD PB OWNER.
the acer bought the bones of PB and just uses The sticker label name PB, there is no PB inside now. just a sticker, PB and poor support, IT AN ACER INSIDE FOR SURE. NOW.
no PC stated
no oS stated
no country stated,
ANSWERS WILL COME HARD.
SELL this pig and buy DELL.
win! have a future.(PC)
have support and endless documentation'
Packard Bell computer
welcome to fixya, USA
no PB sold here since 1999 (2000)
you posted lacking what computer.
my wild guess is its a PC
2nd wild guess is a Laptop?????????
and the windows is dead,MS windows
the screen is not dead.
but windows is, dead. so
1:if Xp its virus infected
2: if not XP but newer,unstated. it is corrupted.
3: or the keyboard is dead (bad) cables fell off etc.
when you power on a PC, you can enter BIOS
using hot keys covered in your manual that we dont have here in USA.
see?
so test 1 is see if BIOS works fist.
using Hot keys.
this is a generic answer,
NO computer stated,
call your PB in your unstated country
we dont have PB in usa, after 1999
they bugged out, on PC. here(red ink max)
Is this a desktop computer with a plug in keyboard or a laptop?
On a desktop type turn off the computer and unplug it from the wall socket. Unplug the keyboard wire from the tower unit and 'Gently' clean the connector tip with a Dry cotton bud. Do the same on the tower unit connector. Plug the keyboard back into the Tower. Plug the computer back into the power point and start up the computer. If it still doesn't work try replacing the whole keyboard.
On a laptop it's more complicated. You need to dismantle the laptop to repair the keyboard. Your easiest solution will be to take it to a Good laptop repair specialist.
SOURCE: keyboard lock
Hi, because it is a Packard Bell your problem doesn't sound odd. I owned one at one point in time. They have since gone out of business. A keyboard that freezes is related to circuit malfunction. You have two options: open the laptop and clean out all the dust from everywhere especially under the keyboard. If that doesn't work reseat the processor. I will walk you through these solutions if needed. Just open a live chat with me. Good luck
SOURCE: Monitor not coming on - Packard Bell Easynote R4650
It's a dreadful way to start a day - you press the power button on your computer and nothing happens. Do not fear because all may not be lost! Follow these simple steps to determine why your computer won't turn on.
Note: It is very important to troubleshoot any issue beginning with the most likely and easily testable problem so be sure to follow these steps in order.
Difficulty: Average
Time Required: Anywhere from 10 minutes to a few hours or more depending on why the computer won't turn on
Here's How:
As silly as it may sound, the number one reason why a computer won't turn on is because it wasn't turned on! Before starting a sometimes time consuming troubleshooting process, make sure you've turned on every power switch and power button associated with your computer:
Power button/switch on the front of the computer's case.
Power button/switch on the front and/or back of the monitor.
Power switch on the power supply on the back of the computer.
Power switch on the power strip or surge protector (if you have one).
Verify that the power supply voltage switch is correctly set. If the input voltage for the power supply does not match the correct setting for your country, your computer may not power on.
Check for loose computer and monitor power cable connections. A loose or unplugged power cable is one of the top reasons why a computer doesn't turn on.
Perform a "lamp test" to verify power is being provided. Your computer isn't going to turn on if it's not getting power so you need to make sure that the power source is working properly.
A damaged power supply could be preventing the computer from being properly powered.
Do a quick test of the power supply by holding your hand behind the power supply fan located at the rear of the case. If the power supply is working, you should feel air from within the case blowing against your hand. If not, you may need to replace the power supply.
Tip: Is the power light on the front of the computer's case on? If you've turned the power switch on but the light is off, this is another good indication that the power supply is the cause of this issue.
Over time, internal components and the cables that connect them can wiggle loose which can often times result in a computer unable to power on. Try reseating the following and then try to power on the computer again:
Reseat the internal cables
Reseat the memory modules
Reseat the video card
Reseat other expansion cards
Reseating the CPU may also be necessary but should only be attempted if the reseating of all other components is not successful. This is due to the fact that this process is a little more involved and can run a small risk of damage to the CPU. This isn't a big concern if you're careful, so don't worry!
Check for causes of electrical shorts in the computer case. This is often the cause of the problem when the computer powers on for a second or two but then powers off completely.
Most monitors have a small light next to the power button that can change between various colors. If the screen is blank, this light is your main source of information about the monitor.
If this light is not on at all, double-check the power switch and connections (Steps 1, 2 and 3) and also make sure the monitor cable is securely plugged in to the video card port on the back of the computer case. If the light is still off, replace the monitor. If it comes back on, try starting your computer again - a loose or unplugged monitor cable may have been the issue all along.
An amber or yellow power light simply means that the monitor is not receiving any information from the computer. In and of itself, this doesn't tell us much.
On the other hand, if the light is amber or yellow, the computer power light is on, and the hard drive is active (making familiar sounds and the hard drive activity light on the computer case is blinking), the computer is probably starting normally but the video card is not sending information to the monitor. Replace the video card.
Beep codes (see Step 11) usually sound when a video card has malfunctioned but this is not always the case.
Is your computer making a beeping sound? Sometimes a computer will turn on just enough to play a series of beeps from the speakers.
These beep codes play in particular sequences and represent a specific problem that your computer is having. Troubleshoot the beep code to figure out what it's saying and then service the computer as necessary.
Tips:
Still can't get your computer to turn on? Let a community of computer support enthusiasts help out! Post the details of your problem in the Focus on PC Support Forums.
SOURCE: lost password for my packard bell easynote
Only way to remove a BIOS password on any computer is to remove all power sources from the motherboard so its memory can be cleared.
First, remove the main battery from the laptop. Then you must locate and find the little coin cell battery (It looks like a watch battery) on the laptop and remove it for about a minute or so. Then you can replace them in the opposite order.
Unfortunately, some laptop coin cell batteries are difficult to locate, or require an in depth dissection of the laptop to get to them. Without the model of the laptop, I cannot tell you how to get to it.
SOURCE: Packard Bell Easynote MZ36 24 uk
You could search the internet for Bios Master passwords. Other than that, just pull the ac power, main battery and cmos battery and let the system drain.
If its a Windows password, then respond back for more instructions.
SOURCE: Packard Bell Easynote MZ36-U-024-UK
Just removing the battery briefly may not reset CMOS. Look for jumpers near the battery clip and if there are some, remove the battery, short any jumpers nearby.
Failing jumpers, I would suggest leaving it without battery for at least a day; some are using 'supercapacitors' and a battery.
Opening a laptop case can be daunting; be advised that after you have removed any screws from the under- & back-side, the mating plastic parts may still have molded parts that will need to be popped apart.
If the slits between the mating parts will accommodate it, an old credit card will sometimes avoid damage to the plastic, otherwise a putty (or spackle) knife will work.
Make sure you are not carrying any static charge before poking around inside; it can be a killer.
Touch any exposed sheet metal or a heatsink to equalize any charge.
