SOURCE: rca preout not putting out anything after amp/subs are hooked up and ready to pound
On most Pioneer's, there is an option in the main menu that allows you to turn the sub-out on or off. This must be on to let a signal pass from the head unit to the amp. Check this, and if it is on, try replacing the RCA cables. Let me know if this helps :)
The tuner feed is at lower level than other sources. Happens. Unit may have a control for this internally and you might want to check it out with manufacturer of unit.
