Coffee Makers & Espresso Machines Logo
L Stuchell Posted on Feb 25, 2018
Unable to set up Bunn coffee maker NHS Brewer for the first time in accordance with manufacturer’s directions. What am I doing wrong?
  • Paul Bade Feb 26, 2018
    Hi L Stuchell, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    Can you describe what isn't working as you expect? Is it a problem with parts not fitting, or the unit never getting warm?
5 Related Answers
Anonymous
  • 131 Answers
  • Posted on Feb 10, 2009
SOURCE: Water supply for Bunn coffee maker
open the cover on the brewer- depending on your model, it could be the front or the back cover. look for a brew timer dial. turn this up slowly, running a brew each time to see if you now have a full pot
Anonymous
  • 131 Answers
  • Posted on Feb 13, 2009
SOURCE: Bunn coffee maker leaks water
There are 3 seals in your unit that could cause your problem. there is a silicon seal right under the pour-in tray, and two on the top of the tank. one of those is for the thermostat, the other is for the sprayhead tube. any of these could leak, causing water to come out the bottom of the brewer. One other thing that can cause this is a scale buildup between the pour-in tray and the tank.
Anonymous
  • 131 Answers
  • Posted on Apr 23, 2010
SOURCE: Bunn 10 cup home coffee brewer is leaking from the
These models have a plastic pour-in tray just under the top lid. The plastic on these trays gets brittle over time with the heating and cooling, and they crack where they mount to the tank. The only real way to repair this is to replace the pour-in tray, but these are not sold anywhere that I have found. You might be able to find a used one at a Bunn dealer in your area.
I have seen some people do a temporary repair by putting a washer under the mounting bolt and sealing it with silicone, but this is a temp. fix at best. By the way, the reason that the water appears to be coming from the bottom of the machine is that there is no other place for the water to come out after it leaks from the top.
Anonymous
  • 189 Answers
  • Posted on May 19, 2010
SOURCE: I have a bunn coffee maker the NHBX is the # it is
Please give Customer Service a call with the model and date code. If the machine is 3 years old or less, it will be replaced with a new machine. If it is older than 3 years, it can be exchanged for a reduced price.
Anonymous
  • Posted on Sep 07, 2010
SOURCE: Tim Horton's home brewer Bunn coffee maker
My Tim Hortons coffee pot leake water out the sides when I add water to make more coffee. What should I do ? I like the coffee maker it makes great coffee,
Bunn-o-Matic HB coffee maker. How do you read the date code on it please?
Question edited for clarity and toss in a load of CAPS.
It is dated with a non intuitive, none readable code. You can see examples here.
Where is my Date Code? BACK OF BREWER Sticker on the lower back of brewer BOTTOM OF BREWER Sticker attached to the bottom baseplate of your brewer. Note: Allow water in tank to cool. Drain water before turning over.
Where is my Date Code? - BUNN
More here
https://www.google.com/search?q=Bunn-o-Matic+HB+coffee+maker+read+the+date+code
Our bunn NHS Velocity was unplugged accidently. Now when we make coffee it is really luke warm and the light doesn't appear on
This is really a home style VPR brewer (but looks nicer)
if you listen to their video (link below) they mention it has a pre-heated tank of water already in the brewer. This means the brewer needs to be pre-filled with a full pot of water and pre-heated prior to using the brewer. Unplugging this unit won't be a problem UNLESS it was emptied of tank water and not refilled when powered up.
* The unit will try and heat up the tank of water but if empty then just air which overheats the unit then blows the thermal fuse. Call for service.
* The warmer is still working but it's not hot enough to brew frequently as the warmer may take up to an hour to get the tank hot enough to brew or it may not get hot at all if it's own thermal fuse blew too.
* Final; call for service to be safe.
Aloha, ukboy57
https://www.amazon.com/BUNN-Velocity-10-Cup-Coffee-Brewer/dp/B00EAQJCWW/ref=sr_1_1?ie=UTF8&qid=1516431654&sr=8-1&keywords=bunn+nhs+velocity
My brewer leaks from base of the brewer
Either leaking from tank lid or fill basin.You will need to take of top of brewer to verify.Parts and breakdown available at the Bunn website.Contact customer service at Bunn.I know at one time they would replace the brewer at a discount rate.
2helpful
Our office is relocating and I need to prepare our Bunn coffee maker to be moved. It appears to be working fine now, but we do live in a hard-water area. So: - Obviously we will be unplugging it. Can it be...
I work for BUNN. Yes, you can empty it - here's a link to instructions http://www.bunn.com/retail/service/faq.html#faq6
Also, it's absolutely a perfect time to do the Periodic Cleaning of your brewer - here's a link to instructions for using vinegar to thoroughly clean your brewer. http://www.bunn.com/retail/service/cleaning.html
If you want to move the brewer without draining, please be sure to unplug it and let the water cool for about 6 hours before moving it (the water inside is 200 degrees). Then, when you get to the new location you can just plug it in and let it heat up.
Any other questions, please let me know. [email protected]
2helpful
Directions
pour the water into the top, just as you would to make a pot of coffee, making sure the brewer is not plugged in. keep filling the brewer until the water comes out the sprayhead, then plug it in and let it heat up, and you are ready to brew.
By the way, operating instructions are available at no cost from www.bunn.com
Water over filling pot
The procedure for setup of this coffee maker can be found here -
http://www.bunn.com/pdfs/commercial/manuals/10613.0000.pdf
Please email if you have additional questions.
1helpful
There is a brew timer on the left side of your machine near the heater switch. you need to remove an access panel to access it. turn this down a little, let the water heat up, then try another brew. Adjust as needed, brewing another pot between each setting.
Bunn Cooffee Maker is not making full pots of coffee
I would ask if this machine has been moved lately- for cleaning or has anyone put anything new around the brewer? If someone has moved this brewer, they might have caused a kink in the line coming to the back of the brewer. this will restrict the water flow to the brewer. this will cause the brewer to brew only part pots of coffee.
Top Bunn Coffee Makers & Espresso Machines Experts
vince
john h
ADMIN Andrew
ADMIN Andrew
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
