peter148
SOURCE: RAM-OS missing
Hi the Pin Pad is ok but it has to go back to a VeriFone supplier to download the operating software. With the Pin Pad not being used for 1,5 years the internal battery in the Pin Pad will have gone flat. Meaning that the Pin Pad has lost its internal software. This software can only be supplied by a Certified VeriFone Dealer.
Posted on Sep 25, 2008
Brian Sullivan
SOURCE: download needed RAM-OS missing
if this is whats happening to your computer otherwise i cant imagine ((download needed RAM))
the beeps are post during post the very first work is done by the ram,all the memory in the ram is first transferred to the hard disk,and remains active untill turned off.
make sure that your RAM is securely seated
test or replace all the leads that attach to your hard drive make sure the connections are secure including electrical extensions + IDE,SATAthe ones that attach from your
((motherboard to hard drive))
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
Posted on Feb 04, 2011
psoftware109
SOURCE: "Download needed RAM-OS missing"
Download needed RAM-OS missing is cause to OS removed itself in sc5000.you need install OS again.
[email protected]
Posted on Mar 08, 2011
J D Wright
SOURCE: Download needed RAM-OS missing
https://www.google.com/search?client=firefox-b-1-ab&ei=98qNWpaoL8Ovggfwk5KwAQ&q=ram-based+os&oq=ram-based+os&gs_l=psy-ab.3..0i22i30k1.3975.4101.0.4621.2.2.0.0.0.0.100.194.1j1.2.0....0...1.1.64.psy-ab..0.2.193....0.Z_8h3_sAF58
ram based os Google Search google.com
Posted on Feb 21, 2018
test or replace all the leads that attach to your hard drive make sure the connections are secure including electrical extensions + IDE,SATA the ones that attach from your
hope this helps
[email protected]
