Question about American Standard American Lawn Mower 1414-16 16-Inch Standard Push Full Feature Reel Lawn Mo
Mixture adjustment honda hru 173
Could you please advise me how to adjust the mixture on the above thanks
  • 155 Answers
Hi this most honda engines dont have a mixture adjustment screw they only have a air bleed adjusment on the front of the carby close to the head though you can only move it a bit either way on some others should be about 2 turns out from closed, the main problem that honda engines have is they will still run with water in the carby , I would try cleaning out the carby bowl first its only held on with a bolt in the centre.
Posted on Aug 01, 2009
SOURCE:
2001 Honda XLR 125 R adjust idle mixture screw
Hi, Anonymous it should be noted that the "AIR FUEL" mixture screw adjustment "ONLY" manages your idle and has no effect on any other circuit also any intake leaks must be repaired before the A/F adjustment procedure can be performed otherwise you will never obtain a proper idle and you will waste a lot of time chasing the impossible. The A/F mixture screw's purpose is to fine tune the fuel charge entering the combustion chamber. The following applies to both 2 and 4 stroke engines:
1. The mixture screw may be sealed at the factory with a Welch Plug please review the following video for removal.
https://www.youtube.com/watch?v=wAXcksgvDkM
2. The mixture screw manages a range of 3 complete 360-degree counterclockwise turns from the bottom/closed position.
3. The mixture screw should have a spring and o-ring for tension and sealing integrity.
4. Turn the mixture screw clockwise until it gently bottoms out, this makes the fuel charge very lean and the engine should not idle if it does then the pilot/idle jet is too big and needs to be replaced with the next size smaller.
5. Turn the mixture screw 1 and 1/2 turns counterclockwise to establish a baseline for starting the engine.
6. To fine-tune the idle circuit, adjust the mixture screw 1/4 turn in or out to achieve maximum idle RPM, wait 15 seconds between each adjustment for the idle to settle.
7. Never go past 3 full turns out this will make the fuel charge rich, foul plugs, and produce black smoke out of the exhaust, if the engine RPM keeps increasing past 3 turns the pilot/idle jet is too small and needs to be replaced with the next size larger.
8. After achieving maximum idle back out the mixture screw another 1/8 of a turn then adjust the throttle cable idle stop screw to 950-1050 RPM.
9. This procedure works great on 99% of all engines, for the 1% that demand a more robust throttle response on aftermarket monster fuel delivery systems additional tweaking outside the box may be necessary.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
How to Idle mixture screw adjustment
How To Carburetor Idle Pilot Screw Adjustment Honda XR70
Honda Service Repair Manual Download
http://www.partsfish.com/page/oem-parts-for-honda
http://mybikemanuals.com/honda/honda-xr-owners-manuals
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
May 19, 2014 | 2001 Honda XLR 125 R
2005 Honda Activa air-fuel mixture adjustment
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Adjusting air fuel mixture screw
Honda Activa Fuel Mixture screw Actual Adjustment and RPM Adjustment
http://www.family-motorsports.net/GY6-50cc-150cc.pdf
Honda activa 2009 Owner Manual
Feb 14, 2014 | 2005 Honda Activa
2009 Honda CRF450X how to adjust fuel mixture
Throttle Response Fuel Screw adjustments
How To 4 Stroke MX Fuel Screw Adjustment YZF CRF KXF RMZ FCR Part 1 of 2
Honda CRF450X 2005 Service Manual
https://www.partsfish.com/page/oem-parts-for-honda
Honda 2009 CRF450X Owner Manual Competition Handbook
Mar 08, 2013 | 2009 Honda CRF450R
Fuel mixture adjustment of honda activa
https://itstillruns.com/adjust-honda-carburetor-5347552.html
Dec 01, 2012 | 2005 Honda Activa
2005 Honda CRF 80 F carb adjustment
Hi, Kyle it should be noted that the "AIR FUEL" mixture screw adjustment "ONLY" manages your idle and has no effect on any other circuit also any intake leaks must be repaired before the A/F adjustment procedure can be performed otherwise you will never obtain a proper idle and you will waste a lot of time chasing the impossible. The A/F mixture screw's purpose is to fine tune the fuel charge entering the combustion chamber. The following applies to both 2 and 4 stroke engines:
Honda CRF80 Carb Adjust Mixture Screw Mod
2007 Honda CRF80F Motorcycle Idle Speed Adjustment Attempt CRF80F CRF100F service manual repair 2004 2013 CRF80 CRF100 Download... $15
HONDA CRF80F Owner Manual
Jun 23, 2012 | 2005 Honda CRF 80 F
1979 Honda CX 500 B air/fuel mixture adjustment
Hi, Dan it should be noted that the "AIR FUEL" mixture screw adjustment "ONLY" manages your idle and has no effect on any other circuit also any intake leaks must be repaired before the A/F adjustment procedure can be performed otherwise you will never obtain a proper idle and you will waste a lot of time chasing the impossible. The A/F mixture screw's purpose is to fine tune the fuel charge entering the combustion chamber. The following applies to both 2 and 4 stroke engines:
Mixture adjustment
cx500 carb balancing part 1
Honda CX500 Shop Manual
Honda CX500 CUSTOM Owner Manual
Apr 04, 2012 | 1979 Honda CX 500 B
1998 Honda CBR 600 F3 air screw adjustment
Hi, Robert it should be noted that the "AIR FUEL" mixture screw adjustment "ONLY" manages your idle and has no effect on any other circuit also any intake leaks must be repaired before the A/F adjustment procedure can be performed otherwise you will never obtain a proper idle and you will waste a lot of time chasing the impossible. The A/F mixture screw's purpose is to fine tune the fuel charge entering the combustion chamber. The following applies to both 2 and 4 stroke engines:
air fuel mixture adjustment CBR Forum Enthusiast forums for Honda CBR...
http://www.fireblades.org/forums/honda-cbr-600/82686-98-cbr600-f3-need-help-please.html
Honda CBR600F4I 2001 Service Manual
Honda CBR600F Owner Manual
Nov 07, 2011 | 1998 Honda CBR 600 F(3)W
1997 Honda XRV 750 Africa twin air-fuel mixture adjustment
Hi, Harrythespid it should be noted that the "AIR FUEL" mixture screw adjustment "ONLY" manages your idle and has no effect on any other circuit also any intake leaks must be repaired before the A/F adjustment procedure can be performed otherwise you will never obtain a proper idle and you will waste a lot of time chasing the impossible. The A/F mixture screw's purpose is to fine tune the fuel charge entering the combustion chamber. The following applies to both 2 and 4 stroke engines:
XRV750 Adjusting the mixture synchronisation How
Honda Shadow VT700C Running Lean Fix Pilot Jet Needle Shim http://service.tanga-moteurs.ro/data/Honda_XRV_750%28Africa_Twin%29%26XL_600-650_V%28Transalp%29_%2787-02_Service_Repair_Manual.pdf
Honda XRV 750 Owner Manual
Sep 20, 2010 | 1997 Honda XRV 750 Africa twin
2000 Honda XLR 125 R air fuel mixture adjustment
Hi, Rjunicke it should be noted that the "AIR FUEL" mixture screw adjustment "ONLY" manages your idle and has no effect on any other circuit also any intake leaks must be repaired before the A/F adjustment procedure can be performed otherwise you will never obtain a proper idle and you will waste a lot of time chasing the impossible. The A/F mixture screw's purpose is to fine tune the fuel charge entering the combustion chamber. The following applies to both 2 and 4 stroke engines:
Pilot Air Fuel Screw Adjustment Explained
Service Manual Honda Xlr 125
Honda XL125L Manual
Jun 30, 2010 | 2000 Honda XLR 125 R
American Standard American Lawn Mower 1414-16 16-Inch Standard Push Full Feature Reel Lawn Mo Logo
486 people viewed this question
Top American Standard Garden Experts
roeb
john h
Marvin
Marvin
Are you an American Standard Garden Expert? Answer questions, earn points and help others
