When the TomTom navigation software (on your SD card) is bad (corrupted, error) an X is shown on the screen ...
You'll want to try to recover the software from your backup (that you have made on your computer).
If you also have the TomTom navigation software on the main memory, try removing the SD card and start the GPS up again. If that works, you'll want to restore/re-install the copy of the navigation software on your SD card.
Otherwise, you'll need to connect your device to the HOME (or MyDrive Connect) software (on your computer/laptop) to see if you can re-install the software.
Recently, TomTom has decided to limit/stop support (including software/maps, etc.) for certain (older) models of TomTom GPS. If your model is one of those, you're out of luck. TomTom is trying to have you buy a new model.
SOURCE: SD Card not showing in my Tomtom go 720 to play MP3
If you want to play mp3 songs from sd card then create mp3 folder and place all the songs in side that folder. Now when you go to Juke box menu it will scan all the songs and you will be able to play them the way you want..
SOURCE: i have just tried to
Red cross issue:
http://www.tomtom.com/support/index.php?Language=1&query=red+cross&FID=1898
SOURCE: tomtom 'one' Toyota--New 2days ago,
Same problem here---Trying to get Toyota to "do the right thing". We're on our THIRD unit.
SOURCE: Tomtom One 130 shows pic of Tomtom, flashing x, pie chart icon on left .
TomTom Home must have corrupted the TomTom's operating system. That is what that symbol means. Contact TomTom support and tell them what model you have and they will walk you through getting the correct version installed.
SOURCE: When I switch on my TomTom, SD card has a red cross?
This problem is due to the memory card not containing the TomTom application or map. To update the application onto the memory card, Connect the device to your computer. Open the TomTom Home application. Click on 'Update My Device'. This should then install the application onto the SD card. Alternativly, you could perform all the steps above without the SD card in the device, this will install the application onto the internal memory. Note: you may also need to install your maps, voices, etc after you update.
