Troubleshoot the epson printer related issues easily. Just visit askprob community and follow the instructions to fix the problem.
http://www.askprob.com/forums/topic/how-do-i-fix-epson-error-code-0x10
You can easily fix the epson printer related issues. just visit askprob community and follow the instructions to fix the problem.
http://www.askprob.com/forums/topic/how-...
SOURCE: Umax Astra 6700 download driver error code 129
here is your code mines
101: EXPOSURE LAMP PROBLEM
120:SCANNER HOME PROBLEM
121:SCANNER HOME
124:SCANNER MOTOR PROBLEM
125:SCANNER MOTOR PROBLEM
126:SCANNER MOTOR PROBLEM
127:SCANNER MOTOR PROBLEM
129:SCANNER MOTOR PROBLEM
130:SICU / SBU PROBLEMS
300:CHARGE CORONA PROBLEMS
301:CHARGE CORONA PROBLEM
303:CHARGE GRID PROBLEM
304:CHARGE GRID PROBLEM
305:CHARGER UNIT WIRE CLEANER PROBLEM
306:CHARGER UNIT WIRE CLEANER PROBLEM
310-316:DRUM POTENTIAL SENSOR ERROR ISSUES
321:LASER UNIT WRITE PROBLEM
322:LASER UNIT 1 SYNCH. PROBLEM
323:LASER UNIT DRIVE PROBLEM
335-338:POLYGON MOTOR PROBLEMS
340-342:TONER DENSITY SENSOR ERROR ISSUES
345:DEVELOPER BIAS PROBLEM
350-355:IMAGE DENSITY SENSOR PROBLEMS
360:HARD DISK 1 PROBLEM
361:HARD DISK 2 PROBLEM
362:HARD DISK 1 PROBLEM
363:HARD DISK 2 PROBLEM
364:HARD DISK 1 PROBLEM
365:HARD DISK 2 PROBLEM
366:HARD DISK 1 PROBLEM
367:HARD DISK 2 PROBLEM
370-375:IMAGE COMPRESSION ERROR
376-377: SICU,IMAGE COMPRESSION ERROR
380-383:IMAGE DATA TRANSFER PROBLEM(SICU, SBU,PRINT CONTROLLER
SOURCE: Canon MP480- 5011 - Printer Error Has Occurred After Scan/Prt
You need to carefully clean the encoder strip. It's the clear strip behind the carriage that runs all the way from right to left. A damp Q-tip should remove any grease or fingerprints.
SOURCE: I got E42 22 error code,it a scanner error,how do I fix it
code 42 error definitely caused by loose flat cable from the scanner down into the electronics. End of the cable does not have a plug, just solder on each element, push the cable into its socket.
