Car Audio & Video Logo
r
richard aceves Posted on Feb 25, 2018
I have 2008 cts 10 speaker bose system , bose amp how do i add an amp and sub to this system ,stock radio has no output for rca jacks tried everything ,now i need to service air bags
Stock radio pulled out old sub i have a jbl 1000 i need wire harness guide
5 Related Answers
Anonymous
  • Posted on Nov 11, 2007
SOURCE: Subwoofer Connection: Speaker wire to Mono RCA
The easiest solution to use your subwoofer is to buy an amp for it. Any old stereo receiver from a garage sale will probably do just fine.
  1. Connect the mono RCA subwoofer output from your Sony with a 1xRCA-to-2xRCA splitter to both the left and right input of the cheap reciever's tape or aux input
  2. connect both speaker outputs of the cheap reciever to the speaker input on your subwoofer. make sure both black (-) outputs on the reciever connect to the black input on the sub, and the red outputs (+) on the reciever are both connected to the red input on the subwoofer.
  3. make sure the cheap receiver's volume is all the way down. turn your Sony up to about the loudest you'll listen to it. turn up the subwoofer amp until it's loud enough to sound good.
  4. leave the subwoofer amp alone, the Sony volume will all you ever need to touch from now on.
You can even now turn off your subwoofer / adjust the volume easily now!
Anonymous
  • Posted on Jul 28, 2008
SOURCE: DOES A 2009 TOYOTA TACOMA
Yes!
Read more:
http://trucks.about.com/od/2009toyotatacomatrucks/a/tacoma_changes.htm
"2009 Toyota Tacoma trucks are fitted with an enhanced standard audio system for 2009, with an AM/FM radio, auxiliary audio input, an MP3-capable CD player and XM Satellite radio capability."
I have an '08 Tacoma, and I bought an aftermarket iPod interface with RCA jacks so I could hook up my iPod and Sirius Satellite Radio.
Anonymous
  • 51 Answers
  • Posted on Dec 27, 2008
SOURCE: Brookstone Wireless Outdoor Speaker with Bose 123 System Problem
AUX usually refers to an INPUT, such as a CD player, etc. No signal comes out of a standard AUX jack, unless it specifically says "Aux speaker output". Instead, look for another speaker output jack, such as remote speaker, B speakers, etc. You may only have one set of speaker output jacks, in which case you would need to connect your wireless speaker to the speaker output jacks along with your main speakers, or buy a little speaker selector switch box to switch between main and wireless speakers. There's usually no harm in connecting more than one speaker set to the same outputs, though it is technically not recommended. In the real world, just don't crank it too loud and you'll be fine. The wireless speaker MIGHT run off of a standard line output also, if the wireless speaker has its own power amplifier.
Anonymous
  • 15935 Answers
  • Posted on Apr 09, 2009
SOURCE: My amplifier has one pair of rca inputs. radio only has 1 output
Subwoofer signals should be MONO - not stereo (hence the single Component out on the radio)
Only use one RCA to send signal to your amplifier.
If you use a Y splitter - the signal voltage will be cut in half - deteriorating the quality, and therefore amplifying "dirty" signal.
If you require further help, simply reply to this thread.
Thanks for using FixYa - a FixYa rating is appreciated for answering your Question.
Anonymous
  • 71 Answers
  • Posted on May 06, 2009
SOURCE: Wiring into walls
Okay, here's the verdict. No such din connector for the Bose AM15's exist. I thought I would take another look to see if anything had changed since I had looked last. Once again, all is the same and it makes using standard wiring a pain. However, it is possible to do what you want to do, which I assume is a nice clean install. I have rigged many of these systems, and, here's what I do.
First, the biggest pain is the 25' LFE cable. Shortening it is a pain because the wires are thin and dificult to splice. Lengthening it isn't a great idea either because you want to keep the cables as short as possible. However, a lesser of 2 evils exist and that is to keep this cable whole. Before you begin, peel the LFE cable from the buch untill it is separated from the bundle. Next, peel the speaker wire for each speaker so the pos and neg for each speaker is together, but, separated from the bundle. Then you'll place the sub where you intend it to go, plug in the 13 pin din (I even looked at vga options...nada) and stretch the cable to the wall and cut one speaker wire at a time (+ and -) being CAREFULL to mark which wire is positive and which is negative after the cut. DO NOT cut the LFE cable, and make sure you give yourself an extra foot or so before you cut the wires.
Once the cuts are complete and you have labeled pos and neg for each wire, you may strip the wire and plug into your regular speaker wire wall plate (banana or clips). On the reverse side of the plate, attatch the pos and neg to the plates making sure everything is consistant. Then, run the wires to your receiver (or vise versa). Regular speaker wires typically distingush pos from neg through some sort of marking on the wire housing.
The other cable you will run is the sub (LFE cable). If you want to just drill a hole in the wall and stuff the cable in and run it to the receiver, that's one way, but if you want to keep it clean, use a single RCA connection wall plate. Then, to minimize loss of LFE sound, run a TV coaxial cable from the sub to the receiver and terminate both ends with RCA terminators.
Once the wires are run to the receiver, double check that all the speakers are hooked into the sub and the wiring is complete. Take a AA battery and mark the location of the speaker that corresponds to the wire. In other words, with the speaker wire, hold one end to one side of the battery and the other end tap lightly to the other side of the battery. You will hear a crackle or pop locating the speaker the wire goes to. Once this is identified, label the wire and plug into the appropriate output making sure the pos and neg are consistant.
A picture is worth a thousand words, so, I drew a diagram and will attach it to this forum asap. Good luck and have a blast!
1helpful
How to hook up car radio to an amp when radio does not have RCA Jacks
They make a type of Amplifier that uses high level input from the speaker outputs. Contact a company called Crutchfield.com for details and prices. You ca also have a radio shop install preamp output RCA jacks to the factory radio, do an Internet search for shops that do this type of retrofitting.
2answers
I bought a sony deck to replace the bose stock deck on my 1996 nissan maxima. I purchased the wiring harness and antena adapter also. I hooked everything up right and getting power but im not getting no...
each speaker in your car runs the wiring thru an amp. So each spkear has its own amp for the bose system. You can not hook up a none bose radio If you do you will need to run new wires and replace all the speakers. Sorry.
2helpful
4answers
I have a 93 chevy and i want a subwoofer put in it.. is there a way to hook it to the stock radio and if their is where
you can buy a radio wiring harness at a discount store or an aut parts store, it comes with directions. Hope this helps Tim
Can I hook the reciever to mm bose subwoofer and 5
if bose unit has built in amplifier .Then your sherwood would have to have a variable RCA output jacks in order to work with sub.Then bose audio input RCA cable would connect there.If bose unit does not have built in amp .Then you would connect sherwood left/right speaker outputs into bose left/right inputs .Then other bose speakers will connect to bose unit
1helpful
Adding Spaekers
If it's an original 321 system (series 1) then it has an audio output on the back. (via RCA jacks) You would still need an amp or receiver to connect the speakers to.. (unless they're powered speakers)
If it's a 321 series II or 321 series III- it does not have an audio output.
If the system has a DVD tray right in the middle of the media center, then it's a series 1.
Otherwise, you'd have to get a 1/8 splitter to come from your Mac's headphone output. (still- you will need an amp/receiver or powered speakers to have both 'rooms' playing the same thing from your computer)
2answers
Subs not as loud as they should be plz help
RCA output level and speaker level output have different voltages and currents. The problem you are describing is common to folks trying to connect an OEM dash unit to an aftermarket amp. If your amp has speaker level inputs, try wiring to those......best bet..buy a new head unit, it'll sound better...louder and cleaner.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_aad3edb7dfa380b9
How to install kenwood kac-9102d in 2006 acura rsx
My recommendation is to get a line level converter. Go to a car audio shop or even best buy and specifically ask for a line level converter. It will have speaker wires in and RCAs out. Connect the speaker wires to the sub woofer speaker wires and then you will have the RCAs to run to your amp. I hope this helped.
-Andrew Hawkins
DOES A 2009 TOYOTA TACOMA STOCK RADIO HAVE RCA OUTPUTS TO ADD A AMP AND WOOFER?
Yes!
Read more:
OEM gm stereo
If your amplifier has what they call High level inputs (basically inputs on the amp that you run the speaker wires from your radio into), you can splice wires from where the connectors are on your rear speaker(s), still leaving the speaker hooked up, and use those as an input into the amp. If your amplifier does not have high level inputs, a convertor is available to turn an audio signal from your radio output speaker wires ( spliced in just as above, leaving the speaker hooked up), into an rca output jack. Or the best thing to do would be to buy another say 2-4 channel amp w/high level inputs and rca inputs and outputs, and run your rear speaker wires into the amp. Then you'll be able to run the rca cables out of that amp and into the sub amp, and you'll have the new amp to power your rear speakers or rears and fronts. That would be ideal. But, A convertor is your best bet. Got em at best buy, circuit city, etc. Hope this was helpful.
Top JBL Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
John
John
 Mikey
Mikey
Are you a JBL Car Audio and Video Expert? Answer questions, earn points and help others
