Cars & Trucks Logo
John jones Posted on Feb 24, 2018
My champion genarter model 41532 will run but not giving out power I need a wiring digram and advice
What is the Spark plug gap for as a 2003 Chrysler P T Cruiser turbo
Ted I hope this helps you champion copper plus-0.050 original plugs, champion platnium power 0.050, autolite platnium 0.040, nkg vpower 0.050, nkg g-power 0.050, bosch fine wire platnium do not gap...preset good luck Jeff
2helpful
I have a 2001 Dodge Stratus and awhile ago I switched the plugs to a Autolite plug. Then I decided there might a problem and went back to the Champion plugs.
I believe the factory originals are champion brand, and would have been platinum, but it should still run decent with the coppers. The only thing I can think of is they are of the wrong gap. Copper plugs do not come pre- gapped at all and need to be done by installer. The gap for your stratus, if it's a 4 cylinder is .050. Wrong gap will cause no power and shaking. Correct champion number in copper is #443, and should say that on the box/plug.
2answers
I need an wire harness digram for an 03 ford taurus from the plug thats already run to the front. Any one have this imma just hard wire it instead of spending a lot of money so please if you have it
If you go to autozones website and make a free account and logon to that account, you can then put in the year make and model and look for the free repair guides. The electric diagrams are there.
2answers
Wiring digram
need year make and model and engine
Need pin locations for analdl connector for a 1996 pontic grand am
Below is a wirinf diagram for the plug. I wasn't sure which engine you had so I went with the 3.1 liter engine. If you need the one for the 4 cylinder or if you need this one bigger (this is the largest I can post on here do to size limits) you can email me at [email protected] but remind me of the make model year and engine size. Hope this helps.
1helpful
My 2003 Chrysler Voyager, 3.3L, SFI, runs very rough and at times it almost dies out while driving. The engine seems to choke up at times. I just replaced 6 old spark plugs with 6 new spark plugs, Bosch...
Chrysler Voyager seem function well on Champion spark plugs. I had the same issue and only after buying Genuine Champion Plugs, the car resonded with power
How does the spark plug wires run on the ford 2.3 liter engine 8 spark plugs
www.muscularmustangs.com/2005/???firingorder.php - Cached
This website gives you the digram
Looking for corolla hatchback 1991 a/c wiring diagram
go to O'reilly or Autozone they will have a book called Chillton or Haynes this book contanes electric digrams and mecanical know how i have one for each of my vehicles...Electrial will give you the color of each wire you just trace it down to where you fell the problem is........best of luck, OH the book runs about 18 to 20 dollars
2helpful
1998 Plymouth Grand Voyager Expresso model 3.3litre spark plugs
Only use Champion spark plugs on a Chrysler product.
Your local auto parts supplier should have info to give you proper plug number. There should also be a sticker maybe on your hood, that has correct number as well.It appears to be RN14PMP5 if you chose the double platinum plugs, or RN14MC5 in the standard copper core. The double platinum are about twice the price but last much longer. Gap is .050". Don't let them talk you into a different brand, Champion only. I have seen too many Chrysler vehicles over the years run bad on other plugs.
Mazda etude alternator genarting excessive heat
1st off you would give everything a good visual examination. Look for loose alternator belt. Also look for wires that could have become disconnected or cut that leads to the alternator.
Then you would hook up a volt meter to the battery cables and check the voltage.
After this you would start the engine and recheck the voltage. The voltage on a charged battery should read around 12.5 volts. While the engine is running turn on a few accesories and speed up the idle a little the voltage should read around 14.5 volts.
If the voltage does not increase suspect either a faulty alternator or regulator.
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
