SOURCE: I have Panasonic SC-AK750 Mini
The F61 indicates protect mode. This means that a problem was detected inside and the unit shuts down to prevent further damage. This is usually the output amp pac or the regulator IC. The amp is attached to the heat sink in the rear of hte unit and should be marked RSNxxx.
Dan
SOURCE: error f-61 on SA-AK640
F61 Power Amp IC output abnormal
Upon power on,
PCONT=HIGH,
DCDET=L after checking
LSI.
For power.
Press [STOP] on main unit for
next error.
SOURCE: Remote malfunction - panasonic dvd stereo system
The remote control and main unit are factory-set to “REMOTE 1”
mode.
If your remote control affects other equipment during operation, you
can switch to operate in “REMOTE 2” mode.
To switch to “REMOTE 2” mode
1 While pressing and holding [AUX] on the main unit
Press and hold [2] until “REMOTE 2” appears on the
main unit display.
2 Press and hold [ENTER] and [2] for at least 2
seconds.
The main unit and remote control are now set to operate in
“REMOTE 2” mode.
To return to “REMOTE 1” mode
Do steps 1 and 2 above but use [1] instead of [2] for both steps.
(“REMOTE 1” appears on the main unit during step 1.)
The remote control cannot work with the main unit if their
modes are different.
“REMOTE 1” or “REMOTE 2” appears on the main unit display when
you operate the remote control.
If “REMOTE 1” appears (The main unit is in “REMOTE 1” mode.)
Press and hold [ENTER] and [1] on the remote control for at least
2 seconds.
If “REMOTE 2” appears (The main unit is in “REMOTE 2” mode.)
Press and hold [ENTER] and [2] on the remote control for at least
2 seconds.
SOURCE: Panasonic DVD Stereo System (SA-PM91D) REMOTE MODE 1
press the enter and number 1 button on remote simultanously
SOURCE: panasonic sa-ak750 display f61 change 3x output ic
F61 indicates that regulator IC is gone, simply replace it.
