That could be a few different things ,broken belt,there's a switch on the belt pulley that stops the dryer from starting as a safety if the belt breaks,you didn't send the model number next time send it,open the door,look around the opening where you put the clothes in and you'll see a tag with the model number on it,could be a bad thermal fuse,high limit thermostat,the only way to tell is by getting in there with a meter and check it,the easiest thing to do is take the lid off and grab the belt and pull on it to see if it broke,check the door switch,push it in and out and make sure it's working,also on the back where the cord connects make sure you have 240 volts there if it's electric,if it's gas then you know you already have power because the light is on.if you need more help send model number and do a few checks and i can help you out.also have you seen any error codes come up,if so send them.
SOURCE: Whirlpool Duet dryer won't start F30
well the sensing light will stay on till it feels wet clothes against it if you in auto dry mode it says it wont start without feeling wet clothes against the silver bars in the vent housing it says it will run in manuel mode even if it doesn't feel them pull the top off the dryer and on the right hand side is a tech service sheet in a plastic bag see what it says
you have a blown thermal fuse. you can get one where they have parts it is about 5 dollars.
SOURCE: whirlpool duet front loader dryer....sensing light won;t shut off
I have a whirlpool electric dryer and it cuts off and shows E 1... What is the problem?
SOURCE: Whirlpool Cabrio dryer won't start - the "sensing" light is on
where are the answers on those stupid site
