Model #LC-60le600u serial # B210869554
SOURCE: No POWER
How many times does the POWER led flash per second? (Dont worry about the OPC).
1x (steady constant blink) = Lamps or inverters
2x = Power Supply
3x = Main Unit
If i am reading it correctly, looks like the POWER led is flashing 2x, which means it is a power supply failure. Either way, your TV needs to have a board replaced, there isn't anything you can do to fix it yourself. Try locating your local sharp authorized service center to repair your TV (1-800-237-4277)
SOURCE: sharp 46 aquos model LC46E77UN tv turned off power
Unplug it hold down the Channel Down button and the Volume Up button unplug it for 10 seconds then plug it back in and continue holding them down for another 10 seconds then release. I had the same issue and this fixed it now I have another though *~*
SOURCE: unit powered off. I unplugged
It's trying to tell you something. Look up the series of flashes in your manual and see what it's trying to tell you. If you don't have a manual, go to the manufacturer's web site and see if you can download one.
if this tv is still under warranty i would be filling a claim straight away this is almost always wither a hardware or firmware fault both of which if stock should be covered under warranty.
good luck.
