My Unstated PC is dead
the PC has no sound, right
the fans in the desktop are dead silent
and do not blow air .(2 fans)
if yes that is why..
or is not connected to this monitor.
the monitor works, we see that.
the errors it shows are true,
that error means the PC is dead.
fixing is last ,not first. sorry.
diagnosis is first, guessing is very expensive.
wana do tests next?
http://pcdied.com/black-screen.html#DT-only
1) Reset your computer.
2) Unplug the cable from the computer to the monitor and check to see if its damaged, if OK plug it back in.
3) On windows computer, click windows key / windows system / control panel / device manager / display adapters (click on icon) / Update driver
the PS is dead, there is no windows on dead PCs sorry helpers...
monitor showing "no input signal"
the manual tells how to do the reset(last link)
but you never said once the 2 fans in the PC are dead. if that is true. I bet yes.
so....
unplug the PC from the wall AC jack.
push power on, the PC will burp, that means it may, spin fans for 1 second. and die.
this is NORMAL
then leave it AC line, unplugged for say an hour. (this discharges things,,, and more)
now plug PC into Wall AC power jack (both ends)
the push power, button now.
the 2 fans inside must spin or the PSU is dead.
there are other things to fail that cause all PSU made to not turn on, ask how to test for that.
PSU testshttp://www.pcdied.com/power.html#rapid_t...
http://h10032.www1.hp.com/ctg/Manual/c00...
SOURCE: crt computer monitor model 6332-03n
Hi, you can try lowering the screen resolution, the color quality and the screen refresh rates. Work from there and observe each setting/increment. soon as the monitor quits, press escape to revert to previous setting. I get the impression that you are familiar with electronics, the problem is your monitor horz. freq is playing catch up and eventually fails. Lowering your PC setting then might do the trick. To lower the settings, right click on desktop, properties, settings tab & advance button - Monitor. Hope this be of some help. Good luck
SOURCE: Monitor status - no input signal. What does this
the problem might be coming from your video card or try changing your RAM
SOURCE: hp w2207 monitor says no input when computer is
try a different monitor, if the display remains blank on a known good monitor, then it is your video card.
SOURCE: how many USB ports does HP / Hewlett-Packard
If you have the standard configuration, this machine has 7 USB ports (4 on the back and 3 on the front).
I hope this helps.
Testimonial: "This HP desktop is a new offering and I could not find any detailed manuals or specs. So thank you for your answer."
SOURCE: how do I fix the error no vga input signal no dvi input signal monitor going to sleep
Check if you VGA is properly settled in the PCI slot. Try to take it out, clean the slot for dust.
If that doesn't help, it is well possible that you VGA is not working any more.
