Yamaha DVR-S200 DVD Player Logo
Posted on Nov 24, 2007
Auto shut down of unit
Hi, Please help if you can.
my dvr - s200 dvd player shuts down frequently when the volume is 80 or over.I would be gratefull of any assistance offered
Thank you
Andrew Porter
[email protected]
A
Anonymous
hello,
If this is happening all the time maybe you should think about the fact that it is not able to operate at this level all the time. I never turn mine up above 60 because the people at Yamaha told me this was the safe volume level. Try that.
Anonymous
Level 1:
Scholar:
New Friend:
  • Contributor 67 Answers
  • Posted on Nov 30, 2007
Anonymous
Contributor
Level 1:
Scholar:
New Friend:
Answers
67
Questions
0
Helped
34931
Points
99
The audio amps may be overheating and shutting down. a lot of electronic devices don't receive heat sink compound when being assembled and the heat doesn't transfer as it should. Try cooling the unit either in a plastic bag in the refrigerator or placing it in a cool airstream directed at the rear of the unit. If it's in a stack of other electronic devices, place something between the units to allow air to circulate. I hot-melt glue tinkertoy wheels to the bottom of the units myself to separate them.
Connect a Dish VIP622 to a DVD/VCR
Hi piautewith the VIP622 receiver connecting to your DVD/VCR player you will need theinput/output jacks. To setup recordings to your VCR/DVD player, you will want torun from receiver output to VCR/DVD input and from VCR/DVD output to TV input. Thefan on the VIP622 receiver is just like the fan in a computer tower. Even ifthe receiver is off the fan will still run to keep unit the right temperature foryour DVR receiver. MikeHouston of DISH Network
The system or DVD recorder turns off itself
It could be because your unit is overheating. Shutting itself off is your player's way of protecting itself. Causes can be form anything to direct exposure to sunlight, Something heavy is on top of the player, to disk speed being to fast.
2helpful
After couple of hours unit shut itself down please help
in the manual it says the DVR will shut down after 3 hours of inactivity . The DVR should put up a message to " press enter " to reset .
hope , it helps .
2answers
Yamaha DVR C300
WHERE CAN I FIND A REMOTE
Unit wont stay powered up
Check for overheating. Place the unit in a large plastic bag and place it in the refrigerator for 1/2 hour. Don't allow condensation to appear on the unit before powering it up, the heat will evaporate any potential condensation. Put moisture absorber or rice in a paper bag in the plastic bag for safety to absorb any moisture. Then power up. If still inoperative check for DC or AC voltage on speaker connectors. If one side is different, or if DC appears on the outputs, audio output may be shorted. See if plugging in headphones stops the problem, some units disable the audio outputs with headphones plugged in.
Repair of portable dvd model 288.
Technicians charge $40 just to look at it. Then $80 an hour.
Throw it away and buy a new one for $100.
Jensen VM9510 Car DVD Player
try each of the four speakers independently. It's likely that ONE is blown (or has a wire shorted to ground) and is causing the unit to shut down.
4answers
Yamaha dvr-c300 dvd playeer
Hi sponge your lens is the problem call a tech to look at your set.good luck.
Power Light shuts off
That is a fault in the power supply My friend Wish i could be more help
Top Yamaha Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Yamaha Televison and Video Expert? Answer questions, earn points and help others
